Truck won't stay running
Old Dec 13, 2024 | 07:41 AM
Thejon's Avatar
Thejon
Does the fuel pump continue to run? Might be tempted to put a gauge on it, see what pressure is doing when it dies. Not just low on gas is it????
The Feul gauge on the dash says quarter of a tank... I think this weekend I'm going to add some fresh gas and see how it helps.
Old Dec 26, 2024 | 03:58 PM
Thejon's Avatar
Thejon
Originally Posted by wheily
id try having a charger hooked to battery and see if it stays running.
Ok, I tried having the charger running while idling. I put some fresh gas in it. Exhaust doesn't seem clogged (started it on a cold day and saw normal condensation coming from the tail pipe). Nothing helped. Gas light is on although I know there's at least a quarter tank... One time the gas gauge showed over a quarter tank and the other time I tried to keep it running, the gauge was on E... Not sure what that means. IDK what's going on...
Old Dec 30, 2024 | 10:38 PM
magnethead's Avatar
magnethead
Need to validate this statement. If the fuel pump is shutting off or failing internally, nothing you do will band-aid a lack of fuel....
Old Jan 5, 2025 | 08:19 PM
Thejon's Avatar
Thejon
Not sure how to test this... I hear the faint "whirring" for a second when I turn the key. Sounds like it's coming on. How else do I test it?
Old Jan 5, 2025 | 08:29 PM
Put a pressure gauge on the fuel rail. There is a convenient schrader valve for just such an occasion. If you don't have one, you can rent one from your local parts store.
Old Jan 6, 2025 | 12:13 PM
Dodgevity's Avatar
Dodgevity
Try the cheapest fix first! Go in the under-hood fuse box and try swapping out the fuel pump relay with another. There are many identical relays, I suggest the trailer relay, if you have that. If that's the issue (it was for me and I was convinced that my pump was a goner based on mileage alone), then just replace the relay.
https://dodgeforum.com/forum/2nd-gen...ng-320k-3.html
Old Jan 7, 2025 | 06:54 AM
Thejon's Avatar
Thejon
I'm absolutely going to try this! Cheap and easy first, no doubt.
