Headlight Issues
Old Dec 15, 2024 | 04:57 PM
Daigs's Avatar
Daigs
Default Headlight Issues
Hey guys. First post here.
Just picked up a 98 Dakota SLT 5.2L. Great truck. One issue I’m having is headlights. They work intermittently.
I pull the switch on and fogs always work. But headlights only work some of the time. If the headlights don’t come on, if I pull on the high beams they only stay on if I hold them.
Didn’t see any loose or burnt wires. Fuses are all fine.
I did replace the stalk a few days ago with a cheap Amazon one and that seemed to solve it. But the problem came back.
has anyone encountered this before? Any recommendations?
Old Dec 16, 2024 | 08:16 AM
Dodgevity's Avatar
Dodgevity
First thing I'd do is replace the bulbs.
Old Dec 16, 2024 | 08:18 AM
Daigs's Avatar
Daigs
bulbs are fine. They do work intermittently. Issue seems to be with the circuit.
Old Dec 16, 2024 | 10:07 AM
Did you check the headlight switch itself, and it's connector??
Old Dec 16, 2024 | 10:10 AM
00DakDan's Avatar
00DakDan
Section Moderator
I'd still be thinking the multi-function switch, it does the high/low beams.
If the high beams are also intermittent then the headlamp switch itself.
Old Dec 16, 2024 | 07:18 PM
Daigs's Avatar
Daigs
yeah I’ll double check everything again this weekend when I have some light. The parking lights and fogs (when I have them on) work 100% of the time when I pull the headlight switch.
But if the headlights don’t go on, when I pull on tye high beams they come in and go off right away. If I hold the switch they’ll stay on. So I’m thinking either another bad switch or perhaps that connector.
