What PSI should be in my tires?
Old Jan 16, 2006 | 07:08 PM
syllinx's Avatar
syllinx
Default What PSI should be in my tires?
The dealer put 275/60r15 tires on it and im wondering what psi i should put since the tires max is 44.
This is for a 2000 dakota v6 extended cab 2wd
Old Jan 16, 2006 | 07:17 PM
boltonranger's Avatar
boltonranger
Default RE: What PSI should be in my tires?
For the 02 quad dakota;
I've been told 36frt/41 rr.
-br
Old Jan 16, 2006 | 07:21 PM
DevilsReject's Avatar
DevilsReject
Noob Assassin
run 38 psi.....that's what I ran on both of my Dakotas, the V6 RC and the V8 CC. I kept it at that psi even when I went to my Kumho street tires...
Old Jan 16, 2006 | 07:26 PM
syllinx's Avatar
syllinx
Thanks .. I will try that I went to 35 and it seems to mess up the mileage. Was getting about 21.2 mpg avg all the time. Now its stuck on 19.8.
Old Jan 17, 2006 | 01:52 AM
kdh97602's Avatar
kdh97602
i got tires 1000 mi ago, they offered n2 and i went for it. both front and rear at 37, i would like to say that it helps the mpg, but to justify that i would need to blead off some and pay for the n2 again. seems to work though.
Old Jan 17, 2006 | 06:27 PM
cbsaint's Avatar
cbsaint
n2? Is that Nitrogen? Why is that preferable to regular old compressed air? Is it a question of being more inert to make the tires last longer, or is there something about it that helps you keep more even pressure?
Old Jan 17, 2006 | 07:03 PM
gutted's Avatar
gutted
ORIGINAL: cbsaint
Nitrogen is lighter.
Old Jan 17, 2006 | 08:40 PM
DevilsReject
Noob Assassin
Nitrogen stays at a constant psi regardless of heat......it doesnt expand and contract like oxygen...therefore you get better gas mileage because your tires are properly aired up.
Nitrogen also doesnt leak out like air...so if you have a flat...there's a hole in the tire.....it's well worth it...but it costs like 30-40 for 4 tires.
It's worth the expense. Properly aired tires will improve mpg, improve driving, and also save you money on tire wear.
