Limited Slip
Old Jun 21, 2006 | 04:32 PM
horatio102's Avatar
horatio102
Default RE: Limited Slip
lil - what exactly are you asking? The codes have a description next to them. You've got a 5-speed auto, lockup torqe converter (not sure why that's listed in the options), 9.25" Chrysler rear diff with 3.55 gears, some pin stripes and paint.
It doesn't appear that you've got a limited slip, since it's not listed.
Old Jun 21, 2006 | 05:20 PM
lil's Avatar
lil
that is what i was wondering limited slip yes or no.........so that means I have ? slips a lot?
Old Jun 21, 2006 | 07:30 PM
lil's Avatar
lil
Hey lookie at what I found
How do I Determine if I have a Locker?
If you don't know if you have a locker, you probably don't. A Jeep vehicle has never come from the factory with a true locker, although limited slip differentials have been optional for years. The limited slip differentials put in at the factory, over the past 20 years or so, wear out quickly and end up acting like a open differential. By the time you purchase a used Jeep, chances are, the LSD will be worn out.
The easy way to tell if you have a locker is to raise and safely support the rear of the vehicle so both back tires are off the ground. With the engine is off and the transmission and transfer case in gear, turn one wheel by hand. If the other wheel turns in the opposite direction, you are open. If it turns in the same direction, you are locked or have a limited slip. If you have a true locker, with one wheel raised, the engine off, and the transmission and transfer case in gear, the wheel should not turn.
Old Jun 21, 2006 | 11:06 PM
horatio102's Avatar
horatio102
Does the Rubicon not have an electric locker? I could have sworn it did.
Old Jun 23, 2006 | 01:19 AM
1996squishysohc's Avatar
1996squishysohc
the rubicon has an electronically contolled, air operated locker. It is a true locking diff, just like a detroit air locker
Old Jun 23, 2006 | 01:21 AM
1996squishysohc
If you give me the vin number to your truck I can send you a printup of all the Info on your truck. Probably will be two pages long
Old Jun 23, 2006 | 01:59 AM
The Burning Rom's Avatar
The Burning Rom
You can also get a build sheet directly from Dodge by going here: http://www-5.dodge.com/wccsapp/unive...ull&category=R
Old Jun 23, 2006 | 06:58 PM
lil's Avatar
lil
Thanks guys
Old Jun 28, 2006 | 04:59 AM
lil's Avatar
lil
Wow that link is so cool I did what you told me I sent them the info they want on that link and a few days later they sent me a full complete detailed email with my build and they also updated Dodge's records for warranty and recall notices, thanks again all you guys for your help
