round filter HELP ASAP
Old Sep 6, 2006 | 04:38 AM
brbcbrent's Avatar
brbcbrent
Default RE: round filter HELP ASAP
hey kota, your post sparked some thinking for my own question whether to do the 14" can or a CAI off to the side. Anyway in my travels around the net I cam across which might be helpful to you...
http://www.dakota-truck.net/UPGRADES/FABM/fabmdml.html
btw - are you planning on fabbing up a functional cowl/scoop to let cooler air in or just satisfied that more air is getting in?
Old Sep 6, 2006 | 01:14 PM
LAKOTA169's Avatar
LAKOTA169
The drop base and spacer is what I used on mine. You can open up the shield next to the radiator and remove the seal at the rear of the hood for a flow-through of air.
Old Sep 6, 2006 | 02:42 PM
OldDodgeDriver's Avatar
OldDodgeDriver
Mine fits with no problem only because of the 2" body lift. If you remove the rubber gasket/seal at the rear of the hood (like I did) you will now direct all the hot engine air directly into the fresh air intake for the a/c & heating ventilation system. Not so bad in the winter, but not fun in the summer! Also you get to live with engine compartment fumes/odors in the cabin of your nice truck! I closed off the center intakes and put foam gaskets/seals on the left and right to block the hot air from enering the fresh air intakes. [sm=signs003.gif]
Old Sep 6, 2006 | 04:14 PM
horatio102's Avatar
horatio102
The other problem with screwing up the engineered airflow underhood is that you're directing air around the radiator, decreasing the effective cooling capability. Ok if you're never working the truck, but on a hot day in traffic or if you're towing/hauling a load you will run hotter.
Old Sep 6, 2006 | 07:00 PM
Mean Green's Avatar
Mean Green
ORIGINAL: LAKOTA169
There you go lakota img tags need to be lowercase.
