ABS & brake light on
Old Mar 15, 2007 | 02:18 AM
MoPaul's Avatar
MoPaul
Default RE: ABS & brake light on
on top of the rear diff, toward the driveshaft. it's under the brackets.
Old Mar 15, 2007 | 02:27 AM
boohoops's Avatar
boohoops
rite on. thanks. im checkin mine tomro
Old Mar 15, 2007 | 10:43 PM
2000dakota4x4's Avatar
2000dakota4x4
Just wondering what makes them go bad? This might be apples to oranges, but my wifes 01 Explorer had this sensor go bad and it had a ton of gunk on it. When I wiped it off most of it is metal, wear from the gears and parts of the dif. Could all this metal throw it off or is that what makes it go bad. And yes I know this axle isn't long for life, it had a bad axle seal got low on oil, I added over a quart. The ABS light issue is how I found the problem.
Old Mar 15, 2007 | 10:50 PM
boohoops's Avatar
boohoops
should i undo the brackets do clean it off? or can i just spray some cleaner around the area?
Old Mar 15, 2007 | 11:09 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
ORIGINAL: steve05ram360
yeah it's the rear diff sensor. you cant clean it as it's a hall effect sensor meaning it's magnetic in nature
http://en.wikipedia.org/wiki/Hall_effect_sensor
when they go bad, you cant revive them with a cleaning.
/\/\/\/\/\ as he said you really cant just clean it and expect it to be ok. if ur lucky it might work for a little while but you will need to replace it for a permanent fix
Old Mar 15, 2007 | 11:56 PM
MoPaul's Avatar
MoPaul
i have heard of gunk building up on them and a cleaning working. i would just replace it for the effort. mine broke when i removed it anyway, so without a spare i would have been sunk. it goes into the pumpkin, so spraying, at any rate, would not clean the vital part.
