Speakers?
Old Oct 18, 2006 | 07:53 PM
CFL MIKE's Avatar
CFL MIKE
Default Speakers?
ok im not looking for subwooffers right now but im looking for good door speakers that can but out a decsent amont of bass id rather not use componet speakers because they are expensive so what do you think is the best door speakers?
Old Oct 18, 2006 | 08:28 PM
akirasoft's Avatar
akirasoft
Default RE: Speakers?
I'll be following this thread as well. OEM stereo is pretty dreadful, need to see what I can do to it without spending a metric buttload of money. I had boston acoustics coaxial stuff in my Jeep Wrangler back a few years ago, was considering going the same route here. Boston stuff necessitates an amplifier for best response tho.
Old Oct 18, 2006 | 09:19 PM
Chris's Avatar
Chris
sony's xplod line is a good way to go for quality sound with zero or minimal modification.
Chris's Avatar
Chris
get your sizes and go to ebay, it will save you a lot of hassle and money.
Old Oct 18, 2006 | 11:35 PM
Erich_121's Avatar
Erich_121
OK, sonys??? no..how about some Infinity Kappas or top of the line Pioneer. I've owned both. They both make some of the best sounding speakers ive ever heard
Old Oct 19, 2006 | 12:01 AM
kurbycar32's Avatar
kurbycar32
component is the way to go, and buy them at crutchfield. you can get a decent set of kenwood components for $160. or you can get a open box or somehting at ebay for half that
http://cgi.ebay.com/KENWOOD-KFC-P507...QQcmdZViewItem
Old Oct 19, 2006 | 12:26 AM
akirasoft's Avatar
akirasoft
ORIGINAL: kurbycar32
he'd have to have the skills to fabricate some sort of place to PUT the tweeter tho.... While the sound isn't as good, I think a GOOD set of coaxial mounts (basicaly a component set but the tweeter mounts in with the woofer) might be a better way to go. That is unless someone has handy a good way to mount them.....
Old Oct 19, 2006 | 03:39 PM
Erich_121's Avatar
Erich_121
yeah i agree, componets just mean a seperate woofer and tweeter, this usually adds the benifit of a higher quality crossover, and allows for the tweeter to be placed closer to your ears. The tweeter can be surface or recessed mounted. If moneys not a factor then id go componet, but 3 or 4 ways would sound great
Old Oct 19, 2006 | 05:25 PM
mooshimanx's Avatar
mooshimanx
I'm looking at this too.
I recently picked up a 2003 QC Dakota 4.7, and the stereo does seem a bit, for lack of a better word, distant. Christmas is coming, and I can't afford all those parts at once.
What do you think the cost is on an upgrade setup; I don't know what kind of system I would need at all. I mostly listen to rock and metal, like Guns N Roses and Van Halen, so outrageous bass and SPLs are not probably necessary.
Old Oct 19, 2006 | 07:13 PM
kurbycar32's Avatar
kurbycar32
component tweeter installs take about 10 minutes. use a hole saw to cut the hole in your panel, the speakers have a flush mount setup. you just pop them in and secure them using the included hardware. the install should not be feared, and is a terrible reason not to use go component. if you have to do it in peices i would start with component front speakers ($100-$200). if you cant come up with $200 i would save up a while longer and get the good stuff instead of a $70 set of speakers. I was in college and i know what its like to be poor but come on, if you can come up with enough for cheap speakers then you should be able to save up for the good stuff too. the seperate tweeters add a whole nother level of sound and clarity that adds to any type of music
