70mm throttle body
Old Oct 22, 2006 | 03:39 AM
powerman556's Avatar
powerman556
Default 70mm throttle body
anyone running a BBK 70mm throttle body on a 4.7? please let me know if it's a worthy purchase or not. thanks
Old Oct 22, 2006 | 02:34 PM
superdak05's Avatar
superdak05
Default RE: 70mm throttle body
they are worth the purchase i am looking into a 70 mm from the fastman.com 180.00. most people with gen 3 are doing this mod with better performance.
Old Oct 22, 2006 | 04:41 PM
horatio102's Avatar
horatio102
70mm sounds pretty damned big unless you're running the mods to need that big of a tb. There are performance drawbacks to going too big on the throttle body.
Old Oct 22, 2006 | 05:59 PM
powerman556
like I said on my other thread... describe to me how more air can be bad. what does a ram air do, force in more air.... what does a turbo do...force in more air. i think you are off your stool on that one.
Old Oct 22, 2006 | 07:03 PM
powerman556
superdak... fastman.com... that's coming up as a lotion website man. i found one at truckperformance.com for 215...i have ordered from them before, excellent service and follow up
Old Oct 22, 2006 | 08:46 PM
Twiztid's Avatar
Twiztid
ORIGINAL: powerman556
Injectors can't keep up with air supply
These are generally used in conjunction with other add ons like intake manifold, injectors, ect....
Your motor is a balance of parts, you never want to go extreme in just one area. 70mm is a huge TB for a 4.7L. There is a guy on here with an RT, user2006 or something. He has an RT with more then average mods was looking at a 53 or 54mm I think. You have a liter less motor so....lets hear what other mods you have.
Old Oct 22, 2006 | 08:57 PM
superdak05's Avatar
superdak05
i am sorry it called thefastman.com
Old Oct 23, 2006 | 02:56 AM
User's Avatar
User
I think his uses a diffrent TB 70mm is huge if its a duel hole TB, but im thinking itd a single, if so then thats actually pretty good, big for a single is like 80mm or 90mm, big for a dual hole tb is like 55mm thats a 408 tb on a 360, and yes i can tell you all about un even moding. I have big injectors and im running way to rich, thats the main reason why im getting a bigger TB, with my cam and headers and injectors it should even out the air to fuel ratio and i shouldnt be running rich anymore.
After i put my tb on im thinking of getting the trucked tuned also. At my local shop. I ran a dyno before all this and got 266rwhp im going to do a dyno after all this tuning and upgrades and see what kind of diffrence it makes.
Old Oct 23, 2006 | 03:28 AM
powerman556
it is a single port throttle body, so 70mm isn't oversized at all. per 2 different dodge dealers (i always call for a second opinion) the stock 4.7l injectors can push up to 25 lbs with the addition of either a performance fuel pump or fuel regulator. i found a couple other info sites and called BBK the manufacture of the throttle body and each claim that it is a direct bolt on with nothing else needed, i think i will go with the addition of the fuel regulator though.
Old Oct 23, 2006 | 05:05 AM
User's Avatar
User
ya tbs are easy to install... bolt on power baby!!
