any one tried sea foam
Old Nov 12, 2006 | 06:18 PM
rhowe's Avatar
rhowe
Default RE: any one tried sea foam
i just did my truck w/88k miles and it barely smoked. put the other half in my wifes car and it smoked just a little more. kinda wanted to smoke out main street but atleast my engines clean.
Old Nov 14, 2006 | 12:46 AM
eg hatch's Avatar
eg hatch
i ran that stuff in my oil for a about a half hour and nothing happend no change in motor. how much did you put in the vacume line
Old Nov 14, 2006 | 12:52 AM
Erich_121's Avatar
Erich_121
i just did it a couple hours ago, tons of white smoke, i had to rev it around 2 grand to get it to do that, after about 25 min of running it i noticed that i had slightly beter throtle response and better idle. Worth 6 bucks to me.
Old Nov 14, 2006 | 02:17 AM
fenderbender's Avatar
fenderbender
you should put 1/3 of the can in the vaccum hose while running, 1/3 of the can where you put your oil in, and 1/3 into your gas tank. the last two with it shut off.
Old Nov 14, 2006 | 04:04 PM
jonnymagnum's Avatar
jonnymagnum
I just dumped all of it down the vaccum hose with it running. cause I always use synthetic oil and I had fuel injector cleaner in the gas already. but if you use regular oil then I would put some in the oil too.
________
SweetInnocents
