V6 to a V8?
on
RE: V6 to a V8?
Not worth it.
You'd need the V-8 computer and wiring harness, and I would only trust the V6 automatic to a stock V8. So if you wanted to add anything to the V8, a differant transmission.
And I don't think the V8 would be a direct bolt up, so you'd have to tinker a little bit with mounts.
It can be done, but it depends on how much time and money you are willing to dump into it. (Wish I was alive when dropping in a differant motor didn't involve so much crap)
RE: V6 to a V8?
its not too bad to do because the 5.2 V8 is the exact same motor as the 3.9 just with 2 more pistons you do need all new computers and wireing harnesses though. shouldnt really cost that much but your best bet would be to find a wrecked dakota in a junk yard that has a v8 that way you get all the wireing and computers with the motor
Trending Topics
RE: V6 to a V8?
i believe 14,000 was an extreme exageration unless your trying to put some crazy really expensive racing motor in there you should be able to get a motor out of a junkyard for about 800 then you'll have cost of labor puting the engine in your looking at several hundred there
on
RE: V6 to a V8?
$14,000, easily?!? Maybe if you take it to some shop, but that would take the fun out of it.
(Following prices are for new items)
PCM is about $350-$500.
Wiring harness probably around $500-$600 (not cheap)
Automatic transmission - $2,000-ish
5.2L V8 - $2,300 (Includes: Cylinder Block With Pistons & Rings, Crankshaft, Connecting Rods & Bearings.)
= around $5,150-$5,400
Of course, not everything has to be new. As dodgedakota98luver said, you can find a junked Dakota and get the engine, PCM, and wiring harness from it. You may want to rebuild the motor if its iffy. Definitly a good idea to rebuild any used transmission.
I'm not sure, but you might have a transmission control module that would have to be replaced.
Of course, there will be little costs for other things (new motor mounts, etc. etc.) and lots of time.
