Aftermarket Radio
Old Jan 12, 2007 | 01:55 AM
  #31
User's Avatar
User
Default RE: Aftermarket Radio
ORIGINAL: ssrt2001
quick question since i think i am the only one with the problem
i bought a new kenwood from best buy and i got the wire harness from there as well since i said i can do it myself. so when i hooked it up the way the harness says i get no sound, the radio lights up and everything else just no sound. and i noticed that the wires from the truck are nowhere close to matching up, colors are off and the negetives are lined up positives. I hooked up a house speaker direct to the radio and it works so i am only left with trying to find out what the wires comming from the truck represent.
does anyone have a diagram? and could tell me what colors go where
anything would help
thanks from the noob with no sound
ORIGINAL: jonnymagnum
if you bought the wireing kit for your truck then it should be easy as cake.
on mine the wires were the same colour as the radio. I just had to match up the colours and solder then together. then pug in the harnesses.
you will have 2 sets of wires for the wireing kit. one of them will have all the speaker wires on it. and the other one will have you power, romote, ground, etc.. one connector is black and the other one is grey. and they plug into the factory plugs. then wires from your mounting kit attatches tothe wires on your deck. and they should all be the same colour (atleast mine were)
and the wiring kit and your cd player should have came with diagrams.
What he said...
but there could be another reason why nothing is matching up, when you took your stock radio out (if it was stock when you got it) was there a black and gray plastic harness pluged into the back of the radio? If it was aftermarket already and you pulled it out was there any plastic peices as all besides the harness to the back of the a/m deck?
Some people are morans and cut the factory harness off, and you are left with small non matching color wires with no labels... this could be your problem. If this is the case you need a REVERSE factory harness they have them at Best Buy also... this will give you your factory harness back so you can plug in your aftermarket harness into it.... if that makes since..
There should be these wires you need to hook up..
Power wires from aftermarket harness to a/m deck.
*Red - Power
*Yellow - Mem
*Black - Ground
Orange + or - (DoNOT hook this up)
Blue - Rem Wire/ Power Antanna (used for amps somtimes)
Speaker Wires from aftermarket harness to back of aftermarket deck.
*White +/-
*Gray +/-
*Green +/-
*Purple +/-
Those are the only wires you should see, the only ones you need to hook up have a * next to them.
Old Jan 12, 2007 | 02:03 AM
  #32
Frenchy's Avatar
Frenchy
Why don't you plug in the orange one? I ALWAYS hear that...
What does it do? Or does it not do?
Old Jan 12, 2007 | 02:23 AM
  #33
F1ashman's Avatar
F1ashman
Need some help from the smart folks regarding radio installation. Have a 97 Dakota with a Pioneer radio/CD deck installed. Display is very faint in the daylight. Have the display on the high side setting already. Display does not change with the headlights on or off. Installer said that Dodges have that as a common problem with aftermarket radios. Am I being BS'd and is there a simple fix since the installer is long gone. Thanx in advance.
Old Jan 12, 2007 | 02:39 AM
  #34
User's Avatar
User
ORIGINAL: Frenchy
Its mostly used for illumination, you know that little **** that turns down your interior lights and guages? Well that wire tapes into that wire so the deck dims when you do it, if you ever hook it up, most of the time it creates more of a hassel then it does work, your headlights blow, blinkers stop working, dash lights wont work, ect.. it happens all th time when we get people coming into best buy saying they installed there deck and nothing working as in light in the car/truck..
one time we actually fixed a guys harness that was crimped together, he crimped the - orange to the postive orange on the same harness... he blew all fuses in the deck and none of his lights worked... it was funny.
some cars are actually made to use it though, thats why they have it on there, but useally its better to leave it undone. Cuz most new decks have an option to be dimmed or not.
ORIGINAL: F1ashman
perfect example. If you want your deck to dim to your headlights and guages.. then you have to hook up the illumination wire (orange wire) its either postive or negative somtimes both, it does more trouble then good.
If you cant see your deck durning the day it useally becuase of the face of the deck i have a kenwood that you cant even see if the sun shines on it, i have the setting memorized though so i really dont need to see it.
Or if the gfx is faint, you could have a bad ground, and your deck could be messed up.. also make sure your dimmer setting is turned OFF.
Old Jan 12, 2007 | 03:09 AM
  #35
ssrt2001's Avatar
ssrt2001
thanks to everyone, but jonnymagnum is the winner with the factory amp wire.
thanks again
Old Jan 12, 2007 | 03:31 AM
  #36
User's Avatar
User
ORIGINAL: ssrt2001
thanks again
ya factory amps dont have standard wiring. You have to do an amp bypass and run speaker wire to all the speakers, unless you can buy an amp bypass harness, they make them i think there like 30-40 bucks. Not sure,
