Dodge Dakota automatic transmision
Old Feb 2, 2007 | 08:06 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
Default Dodge Dakota automatic transmision
i have 98 dakota sport with a 3.9L V6 magnum and automatic transmision, lately i have noticed the truck not wanting to shift out of second gear and into third, this is fixed only by wiggling the shifter so that the selector just shows the transmision in the Drive position. If i put the truck in gear so that the selector just shows up as drive, on the high side of the gear selector, toward nuetral, it works, as soon as i put it into the position that is supposed to be full drive it doesnt want to shift out of second gear, any help on this would be appreciated and of course the sooner the better because this problem is really bothering me.
Old Feb 2, 2007 | 08:09 PM
Chris's Avatar
Chris
Default RE: Dodge Dakota automatic transmision
Sounds like your in-dash gear indicator might be a little off. If you are able to get into third and fourth gear when the gear shifter is put farther toward nuetral, then that would most likely be the problem.
Old Feb 2, 2007 | 08:10 PM
Chris's Avatar
Chris
By the way, mine is a little off too. When I am in drive, the little red gear indicator is only half-way under the "D". Ours must have been built on a Friday afternoon.
Old Feb 2, 2007 | 08:21 PM
imnothot02's Avatar
imnothot02
you dont think it has to do with this https://dodgeforum.com/m_663288/tm.htm
ORIGINAL: virused
Old Feb 2, 2007 | 08:29 PM
Chris's Avatar
Chris
ORIGINAL: imnothot02
ORIGINAL: virused
This is definately a possibility. However, in that thread, he wasn't able to get into second. In this case, the person is able to get into all gears, it is just showing a little off in gear selector's window.
Old Feb 2, 2007 | 09:23 PM
shrpshtr325
THE ULTI-MOD
yea probably friday afternoon and also probably the last trucks off the line for the day, glad to hear that im not the only one with the problem because i dont know if the problem was there when it was new i just bought the truck in november
Old Feb 3, 2007 | 02:41 AM
jonnymagnum's Avatar
jonnymagnum
ORIGINAL: virused
mine does that too. and my shifter is a lil loose.
Old Feb 3, 2007 | 03:37 AM
User's Avatar
User
ORIGINAL: jonnymagnum
ORIGINAL: virused
same here.
Old Feb 3, 2007 | 06:16 AM
varsis's Avatar
varsis
You can pull a panel off under the driver side and move the gear selector and look for a peice that moves there is a adjusting ring for slight adjustments worth a shot. Tv cable causes for irratic shifts in almost every gear, it seems like it is just off and may look in d but may be in 2nd. Try adjusting it just turn this plastic type nut which adjusts the cable of course if that fails you can buy a new indictator which will run you 50 bucks...
Old Feb 3, 2007 | 03:05 PM
jonnymagnum
meh.....I'm not worried about it.... I got bigger things to fix[:@]
