How can you ruin your transfer case?
Old Feb 12, 2007 | 01:28 PM
dak3.9's Avatar
dak3.9
Default How can you ruin your transfer case?
I know you can ruin it by driving it on dry pavement (common sense). But how else can you ruin it?
Old Feb 12, 2007 | 05:56 PM
Erich_121's Avatar
Erich_121
Default RE: How can you ruin your transfer case?
When you say ruin it on dry pavement it all depends. If you have 4wheel high then no, if you have part time 4wheel then yes. Do some searching on the forums. Drain the fluid out of it and it will die trust me.
Old Feb 12, 2007 | 11:00 PM
imnothot02's Avatar
imnothot02
put er in 4 low and drive in circles wont be long
Old Feb 12, 2007 | 11:18 PM
dodgerules86's Avatar
dodgerules86
Ah, how to destroy stuff.
Or, as imnothot02 and erich_121 said, you can put it in 4WD (if you have part time 4WD) and drive around on dry pavement.
Old Feb 13, 2007 | 01:58 AM
dodgedakota98luver's Avatar
dodgedakota98luver
i got a good one for ya. put it in 2 wheel. hold the brake spin the back tires really fast without the truck moving *preferably on a slick surface so you dont kill your tires* then with it wound up SLAM it in 4 wheel and your transfer case will sit there and grind and yeah it should be shelled
Old Feb 13, 2007 | 02:08 AM
jonnymagnum's Avatar
jonnymagnum
so.... I guess I will be the only one to ask this...... why do you wanna wreck your transfer case?
Old Feb 13, 2007 | 02:10 AM
Rakaric's Avatar
Rakaric
I guess he wants to know how NOT to screw it up.
Speaking about 4WD. Why does my 4WD low not engage. 4WD high is fine. I tried switching to it last year, but once I started moving, and shifter went out of place and it started to grind. And it was in the snow, btw.
Old Feb 13, 2007 | 02:14 AM
dodgedakota98luver
my gf's dads gen 1 dakota does that. the 4 wheel works great but you have to hold the shifter back with your hand or it will pop out something to do with a spring i think
Old Feb 13, 2007 | 02:16 AM
jonnymagnum
the tranny has to be in neutral before you put it in 4 low
Old Feb 13, 2007 | 02:29 AM
dodgerules86
ORIGINAL: jonnymagnum
And you need to shift pretty fast, too. If you shift slow, it will grind. [:@]
