digital odometer/gear lights
Old Feb 21, 2007 | 05:26 PM
Rakaric's Avatar
Rakaric
Default digital odometer/gear lights
Hey, when I turn my lights on, for some reason the lights for the digital odometer/gear dim, but I already messed with the cargo lamp adjuster. Is there something wrong electronically?
Old Feb 21, 2007 | 05:43 PM
Chris's Avatar
Chris
Default RE: digital odometer/gear lights
Does using the adjuster change the brightness at all?
Old Feb 21, 2007 | 07:23 PM
Rakaric's Avatar
Rakaric
well, yea it does. The functions work, but....when I turn on headlights, the lights dim on the odometer and such, which I know is able to be controlled by the cargo lamp adjuster. the first of the 3...dots as it has in the picabove the **** adjuster, is responsible for keeping the lights bright, but it's not doing the job.
Old Feb 21, 2007 | 08:43 PM
2000Dakotadriver's Avatar
2000Dakotadriver
Just out of curiosity how much does it dim? Is it only a little bit or does it black out?
Old Feb 21, 2007 | 09:10 PM
Chris's Avatar
Chris
IIRC, the dimmer adjuster has 3 settings. First setting the adjuster moves freely and controls the brightness of the lights. Second setting, which is turned on when you move one click above the brightest of the first setting. This keep the instrument panels as bright as if during the day. The third setting turns the dome lights on, as well as turning the instrument panels to daytime setting.
Chris's Avatar
Chris
It is also a possibility that you may have some burned out bulbs behind your instrument panel.
Old Feb 21, 2007 | 10:17 PM
Rakaric's Avatar
Rakaric
well i know the very top setting turns on the bed light, the one below is the done light, and the one below that keeps the brightness on. I guess they may have burned..but I'll check it out later...I'm havin a bit of trouble with the remote starter which I'll prolly be makin a topic on cuz it's not working so well even tho I checked all the wires.
Old Feb 21, 2007 | 10:18 PM
Rakaric's Avatar
Rakaric
ORIGINAL: 2000Dakotadriver
they just dim a little bit, but not black out. but it's hard to tell what it says during day..
Old Feb 21, 2007 | 10:28 PM
f0x672's Avatar
f0x672
w/ the lights on and they dim, i beleive thats a safety feature for when ur driving at night so the light is less intense on your eyes focusing on the road during night hours
Old Feb 21, 2007 | 10:31 PM
Rakaric's Avatar
Rakaric
yes, but it also has the option of havin them as bright as if the headlights were off. It was working a few days ago.
