Poor braking
Old Feb 24, 2007 | 03:39 AM
PJS400's Avatar
PJS400
Default Poor braking
98 V8 Auto - Brake pedal will literaly go to the floor when "standing" on it but will not lock up either front wheel (rear ABS) or stop the truck very quickly. Replaced front discs and adjusted rear shoes (helped a little) but still have poor braking. Thinking maybe the power booster is bad. Anyway to check? Suggestions?
Old Feb 24, 2007 | 03:57 AM
dodgedakota98luver's Avatar
dodgedakota98luver
Default RE: Poor braking
bleed your brake lines before you go for anything expensive. might be something as simple as air in the lines, could be brake booster or master cylander though.
Old Feb 24, 2007 | 05:11 PM
imnothot02's Avatar
imnothot02
i second that, could be multiple things but start with bleeding, then I would checking mabie changing your rear pistions, but im guessing its either air or like you said the booster...just my .02
Old Mar 2, 2007 | 12:38 PM
imnothot02's Avatar
imnothot02
huh wonder what it was...
Old Mar 2, 2007 | 03:45 PM
Chris's Avatar
Chris
Most likely a failure of the master cylander or air in the lines.
Old Mar 2, 2007 | 03:47 PM
Chris's Avatar
Chris
For futue reference for everyone out there:
If the problem is getting progressively worse, it is most likely your brake master.
If it just sucks all the time, but doesn't really get worse, it is most likely a pad issue, rotor issue, caliper issue, pinched hard line issueor air in the lines
Old Mar 2, 2007 | 09:54 PM
DODGERAM808's Avatar
DODGERAM808
usually when the master cylinder is going, while stoped at a light the pedal will slowly sink to the floor. if this just happened all of a sudden i cant see how you got air in your lines unless you went off roading and punctured a line, but if you have no puddle of fluid that isnt it. I would start by changing both rear shoes and go from there.
Old Mar 3, 2007 | 06:18 AM
imnothot02's Avatar
imnothot02
could be a vacuum line too...
Old Mar 4, 2007 | 06:39 AM
TexasTodd's Avatar
TexasTodd
I have 114,000 miles on my 01, QC, 4.7 manual 4x2 Dak.
I also have the ORIGINAL brakes, rotors (never turned), pads, shoes, etc!!
Still stops great too.
Using your parking brake at every park, keeps the rear drums in adjustment, which takes the work off the front rotors/pads, and keeps them working well.
Not waiting until the last possible millisecond to stop also takes work off the brakes, as well as mild downshifting of the manual tranny. :-)
Old Mar 4, 2007 | 02:21 PM
imnothot02's Avatar
imnothot02
ORIGINAL PADS wow i wouldn't [sm=gears.gif][sm=happybounce.gif]wanna drive with you that must be a boring rideor ya just drive on the highway
