Do i need A/C
Old Mar 2, 2007 | 08:41 PM
BigNasty01's Avatar
BigNasty01
Default Do i need A/C
My 99 5.2 Dodge dakota is currently in the shop. They told me i couldnt bypass my a/c but to have it fixed is about $600 and i dont have that kind of money so any alternatives or advice would be greatly appreciated.
Old Mar 2, 2007 | 10:46 PM
imnothot02's Avatar
imnothot02
Default RE: Do i need A/C
buy the smaller belt and don't use it...ask what is wrong that is 600 bucks...see what they tell ya is wrong...it may just be low on refrigerant and they are trying to take you for a ride i have a small leak in my grand am, i have to fill it once a year or so...but its not worth it to me to change out the evaporator
Old Mar 3, 2007 | 12:11 AM
BigNasty01's Avatar
BigNasty01
They say the compressor is locked up but i cant find any reason why my truck wouldnt run without the a/c hooked up.
Old Mar 3, 2007 | 12:25 AM
imnothot02's Avatar
imnothot02
it will.... and find a compressor at a junk yard you can do it urself
Old Mar 3, 2007 | 12:31 AM
batman13's Avatar
batman13
If they say you can't bypass your A/C they are milking you
It's BS i tell ya, you just need a smaller belt and it'll run right around it
if the compressor pully is in the way 4 bolts hold it down but not for long,
you will actually free up a couple horses by passing it
________
AVANDIA HELP
Old Mar 3, 2007 | 12:44 AM
superdak05's Avatar
superdak05
what you need to do is measure the belt lenght with out going around the compresor. and go to the auto parts store and see what lenghts they have. depending on the lenght you may need to put a belt off of a ford or chevy, but dont worry .a serpentine belt is a belt.
Old Mar 3, 2007 | 01:06 AM
imnothot02's Avatar
imnothot02
string is great for this subtract i think 1 inch for the tensioner
Old Mar 3, 2007 | 06:04 AM
dodgedakota98luver's Avatar
dodgedakota98luver
or you could just ask for the belt without A/C for your truck unless its different on the 5.9 than the 5.2 look for a belt routing diagram see if it shows for without A/C as well
Old Mar 3, 2007 | 06:20 AM
imnothot02's Avatar
imnothot02
excelent point...on my 4.7 it doesnt...
Old Mar 3, 2007 | 04:36 PM
imnothot02's Avatar
imnothot02
here is ur belt...if ya wanasweatand have foggy windows in the rain... http://www.oreillyauto.com/EW3/Produ...riptionId=2601
proaly a a/c clutch, check it first ... here that is http://www.oreillyauto.com/EW3/ByKey...scriptionId=27
