new plugs, stll rough
Old Mar 12, 2007 | 10:59 PM
batman13's Avatar
batman13
Default new plugs, stll rough
I put a set of champions in the truck today but she still idles rough.
anybody have any ideas?
I've got the 2.5l 4-cyl
Old Mar 13, 2007 | 12:02 AM
demarco0129's Avatar
demarco0129
Default RE: new plugs, stll rough
I had put some bosch plats in a while ago and while it smoothed out my idle i lost gas mileage. Went back to the champions a couple days ago and mileage seems to have gone back up, but the idle isnt as smooth. I heard NGK V Power have a good idle and dont change mpg much. Maybe try those if you have time, otherwise I hear cleaning the throttle body helps a lot. I personally dont want to do mine because I am afraid to screw something up, but if you have more knowledge or experience then me I would try that. I also had to have a gasket replaced about a year ago because it was leaking oil, and that smoothed out my idle somewhat. Also O2 sensors may make a difference if they are dirty. Lots of variables here....anyone else know where he should start?
Old Mar 13, 2007 | 01:27 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
my truck would do that occasionally until i cleaned the idle air control valve, if you want to try it pm me and ill give you some instructions on it but i hav to remeber them so. just remeber it fixed mine, but my truck has the v6 in it too
Old Mar 13, 2007 | 03:02 PM
CL350RR's Avatar
CL350RR
check all of your vacuum lines. even a smallvacuum leak will make it run rough
Old Mar 13, 2007 | 06:22 PM
jonnymagnum's Avatar
jonnymagnum
did you gap your plugs?
Old Mar 13, 2007 | 08:51 PM
demarco0129
Thats a good point, even if they are supposed to be pregapped some of them are always off just a little. Did you make sure to put the wires back in the right order? A buddy of mine did that he had lots of problems, but it still ran for a day or two till he had time to redo it.
Old Mar 13, 2007 | 11:50 PM
batman13's Avatar
batman13
I gapped then myself and checked them three times before i put them in
and i changed one at a time to get the wires right
It runs fine for about a minute then it gets rough like i've got headers( blubblub-blub, engine shakes)
but after i rev it a bit it smooths out and is usually fine
she also has a backfire habit that comes with a sudden bogging of the engine
i'll try cleaning it up, and CL350RR, how would i check the lines? sounds like a job to do.
Old Mar 14, 2007 | 01:19 AM
admhotel's Avatar
admhotel
Does it do it when it is cold, or more when it is warm? Also when you rev it the skip goes away? and stays away?
Sounds like the idle control valve. If it was a vacum leak I would think as soon as you let it idle down it would start to skip again. Was it skipping before you changed the plugs?
Old Mar 14, 2007 | 03:14 PM
batman13's Avatar
batman13
it does it any timeI start it after being off more'n ten minutes
warm or cold
It usually stays away after i gas it a little
It's done this since i got it and i've put two sets of plugs in
batman13's Avatar
batman13
warm or cold
