HOW TO: Make the O/D default to OFF on start
Old Mar 15, 2007 | 01:50 PM
HankL's Avatar
HankL
Default RE: HOW TO: Make the O/D default to OFF on start
another take on the same subject written several years ago:
http://www.dodgeram.org/tech/mods/tr..._inverter.html
Old Mar 15, 2007 | 05:43 PM
rtkota5point9's Avatar
rtkota5point9
I was going to do it exactly like that describes, but I didn't think you could press the button while the truck is actually cranking. I thought it would only work before or after crank (not sure why I thought that). Probably because a lot of things drop out while cranking. but if that works then by all means do it that way. The diagram above would work exactly the same, just hook the "ignition" wire to the starter wire instead, and you won't need the capacitor or resistor.
Good find!
Old Mar 15, 2007 | 10:58 PM
craigstockman's Avatar
craigstockman
yeah hard to explain in words i'll just take a look. thanks for the posts
Old Mar 16, 2007 | 12:23 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
if you could please excuse my ignorance i dont understand why you would want to disable od every time youdrive,i mean its there to save gas, unless ur towing a trailer, then it makes sense, but not under normal driving could someone explainthis to me
Old Mar 16, 2007 | 01:01 AM
imnothot02's Avatar
imnothot02
45 and below dont use od ruins trannys...SO if ya drive this all the time it would be off for ya! just like oh say the airbag on off switch...
Old Mar 16, 2007 | 01:13 AM
shrpshtr325
THE ULTI-MOD
i usually drive right around there so i guess im best off leaving it on but thanks for clearing it up for me, but y does it ruin the tranny, does it want to shift more or what?
Old Mar 16, 2007 | 01:27 AM
imnothot02's Avatar
imnothot02
doesn't necessarily, but it will try to use od which is useless at low speeds and it causes allot of UN nessary shifting...
Old Mar 16, 2007 | 12:10 PM
rtkota5point9
Exactly. The trans will ALWAYS try to shift to the highest possible gear. So even at in-town speeds, it will shift into O/D, which is useless, and everytime you go a little faster, or accelerate quickly, it needs to shift back out, then back in, then out, then in, ect. So everytime you reduce the amount of shifts the trans makes, it will prolong it's life.Staying out of O/D, the trans will stay in 3rd nearly the entire time, until you come to a stop, orWOT for some reason. It also locks the torque converter when you're out of O/D. That and it makes your exhaust soundbetter too. lol
So the real question is... Why WOULDNT you do this?
