Starting the build process
#121
Ended up with 0.155 of converter clearance with the 1/4" midplate plus an .065 shim. New converter uses 7/16-20 converter bolts, ARP says 55 ft-lb, I say no way. I couldn't get past 40 safely.
Whole album: https://goo.gl/photos/FRnJnnHHfBxTfFbK8
#122
#123
Eighty-Three and one-quarter inches....... Take this and add 2" for the width of the carrier and 1/2" for how far the splines stick out past the seal.
#125
#127
#128
Need to order another set of BBK 1118 O2 sensor harness extensions. They're only 12", use one for the right front and extend one to 3 feet for the other rear sensor...still need to have exhaust made though. That will make the 5 O2 sensor codes go away, leaving the 4 transmission codes. I stole the sensors/solenoids from the 42RE to plug into the harness and zip-tie to the frame rail, which along with some tuning magic, should make all the codes go away (0720 is the only concerning one).
P0031 - Not listed in FSM (O2 heater?)
P0743 - Torque Converter Clutch Solenoid/ Trans Relay Circuits
P0753 - Trans 3-4 Shift Sol/Trans Relay Circuits
P0051 - Not listed in FSM (O2 heater?)
P0132 - 1/1 O2 Sensor Shorted To Voltage
P0152 - 2/1 O2 Sensor Shorted To Voltage
P0138 - 1/2 O2 Sensor Shorted To Voltage
P0720 - Low Output Spd Sensor RPM Above 15 mph
P1763 - Governor Pressure Sensor Volts Too Hi
#129
#130
That's the plan. If it doesn't work, plan B is finding/ordering a 2000+ 3.9/5 speed computer. But hoping this will work at least to pass inspection, since I'll already be needing a 2000+ 5.2/5 speed PCM for the V8 swap.
