2nd Gen Durango 2004 - 2009
spark plugs
Old Feb 9, 2008 | 03:25 PM
MrNobody's Avatar
MrNobody
Default spark plugs
How big of a pain is it to change the plugs in the HEMI for an 05 Durango? I can work on about anything, well at least enough to screw it up. I just can't bring myself to pay $300+ for a change in plugs. Let me know your thoughts.
MrN
Old Feb 9, 2008 | 03:49 PM
Wishbone's Avatar
Wishbone
Default RE: spark plugs
Well the Hemi has 16 spark plugs which really sucks. [:'(]I have looked at that engine and the two rear ones on each side look a little tough but do-able. Probably have to take off all the air intake stuff and go from there.
Use copper core plugs and not platinums or iridiums!
Old Feb 9, 2008 | 08:44 PM
Mechster1's Avatar
Mechster1
It's not that bad to change the plugs. It takes a couple of hours to do the job. I'm pretty tall so its not hard for me to reach the rear plugs, but large hands go with being tall and itis pretty tight way backthere.I changed mine at 32k milesand they were beginning to show a little wear.
Make sure you getsome dielectric grease for the spark plug boots.
Mechster1
2005 Durango Hemi
2005 Neon
1996 Ram 2500
1987 Dodge Raider
Old Feb 10, 2008 | 01:41 PM
LDHarris's Avatar
LDHarris
My take on the plug change is it does take some time. I broke mine down into right and left on different days. I think the total time was 3-4 hours. The rear ones on each side are the hardest to do and they will challenge you the most.
$300?? Wow, I never even checked to see what it would cost, but glad I am able enough to do it myself. I say go for it, its not that bad. The big thing I had to fight was taking off the plug wires, one pulls out and the other is held on with two bolts.
Good luck and let us know how it turns out.
Old Feb 11, 2008 | 10:12 PM
thedispatcher's Avatar
thedispatcher
Is there a reason not to use platinums or iridiums? Not sure what to use.
Old Feb 12, 2008 | 07:31 AM
Wishbone's Avatar
Wishbone
Use Copper, is what came on these trucks. The others run too hot for these engines.
Old Feb 18, 2008 | 11:13 PM
master tech's Avatar
master tech
Site Moderator & Tech
For all of those who havethe 5.7 motors, I find taking the inner fender well out, and they are bolted with 5/16 screws and remove the plugs from the bottom. It took me only one hour to change 16 plugs.
Old Feb 19, 2008 | 10:08 AM
MrNobody's Avatar
MrNobody
I found a dealership to do it for $203 and the let me "test drive" a car for about an hour and a half while they worked on it.'
MrN
Old Feb 23, 2008 | 09:46 AM
alienyzf's Avatar
alienyzf
Do a search for tips for plug change on hemi. Its all you need to know. I also put platinum plugs in and have had zero problems for 20k miles on my ram and 15k miles on my durango. Don't believe everything you read.
John
Old Mar 23, 2008 | 12:24 AM
wicked_5.7Hemi's Avatar
wicked_5.7Hemi
i have a 2005 dodge durango Ltd 5.7Hemi and is up for a 30k maintenance... i'm thinking on replacing the spark plugs with NGK Iridium lX spark plugs...
