2nd Gen Durango 2004 - 2009
Gas fill overflow on my 06 durango
Old Feb 27, 2012 | 08:02 AM
  #301
tinmanwpk's Avatar
tinmanwpk
Another true story on this off topic...A not-so-intelligent individual used an acetylene torch to cut open a 55 gal. drum that had been used to store gasoline. He had known what was previously in that drum. He is no longer with us.
Old Feb 27, 2012 | 10:07 AM
  #302
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
I had to pay $231.00 with tax and a couple gallons of fuel for my repair and Chrysler picked up $700.00 balance. They refunded me $201.00 today, but would not refund the taxes. If you had to pay for the repair send in your receipt and they should reimburse you less taxes.
FF
Old Mar 1, 2012 | 10:13 AM
  #303
sarguy01's Avatar
sarguy01
Update: Today I got mine rediagnosed and was told that not one, but two valves were stuck. I need the fuel filler tube and the gas tank. The gas tanks are in stock in NY but the filler tube is backordered indefinitely. So, I guess I am still out of luck because no one knows when the filler tubes are coming back in stock.
As to the TSB, I have a solid theory on why my 2006, along with others, is not covered under the TSB. When quoted the price for the filler tube, 434$, it was different than the price on the TSB filler tube. I asked my service guy and he went and checked with parts. When my VIN is pulled, a different filler tube part number comes up. So, my theory is the TSB only applies to those Durangos that use the filler tube listed, not my Durango that uses a different filler tube.
I guess I am not getting this fixed before deployment in 9 days...
Old Mar 1, 2012 | 10:19 PM
  #304
IndyDurango's Avatar
IndyDurango
sarguy01,
First, thank you for your service. Stay safe! Past USAR here (MOS72E)
On the backorder of parts, that all started when parts providers lost their asses after the bankruptcy. Some got nothing on millions of dollars worth of shipped inventory to Chrysler. Needless to say, many didn't make it. Most folks would be shocked at how small some suppliers are to the Big3 Automakers. The remaining parts providers were not immune to the proceedings either. Most lost a lot during the bankruptcy too. Thus their old $15 parts are now $45 to try to make some of that lost revenue back.
Good luck on having it all in stock for when you get back.
IndyDurango
Old Mar 2, 2012 | 01:42 PM
  #305
c1971ace's Avatar
c1971ace
Well to add a new twist to all this it turns out that Chrysler has done a revision to the TSB. Its pretty much the same as the original except for that its now covering Durangos built from 02/01/06 thru 03/01/08....
Old Mar 2, 2012 | 01:47 PM
  #306
sarguy01's Avatar
sarguy01
That would go along with my theory that the filler tube changed mid year.
Old Mar 3, 2012 | 07:38 AM
  #307
Dramer77's Avatar
Dramer77
they need to go back into 05 so i can get mine fixed..
Old Mar 27, 2012 | 08:24 PM
  #308
c1971ace's Avatar
c1971ace
Got my filler tube replaced today....turns out it was warrantied. Filled up right afterward was sunny 48°....no spit back at all.
Old Mar 30, 2012 | 09:54 PM
  #309
JMMurrin's Avatar
JMMurrin
Got mine repaired last week. Was skeptical as the dealer wouldn't confirm that the parts were in stock prior to me driving 40 minutes to get there. Thankfully, all went well and I didn't pay a dime. Filled up this week with no trouble! Yay!
Old Mar 31, 2012 | 07:59 AM
  #310
1969CoronetR/T
vaffanculo
My charcoal canister is now purging out the fuel door and down the side of the Durango. I wonder if it is contaminating the fuel and clogging up the fuel filter. Does anyone esle have this problem after their tank and inlet tube were replaced or repaired?
FF
