2nd Gen Durango 2004 - 2009
Fill plug on rear diff
Old Jun 28, 2010 | 09:25 PM
01ssreda4's Avatar
01ssreda4
OK, but every diff I have worked on the fill plug was easily located. I looked on the main housing everywhere and didnt see one.
Old Jun 28, 2010 | 09:48 PM
Big_Wheel's Avatar
Big_Wheel
im not at home right now or i'd take a picture... is there a rubber plug/grommet on the cover?
Old Jun 28, 2010 | 09:51 PM
01ssreda4's Avatar
01ssreda4
Nope, only thing on the cover is the suspension bar that bolts through it. I suspected this maybe could be used as a fill plug when the bolt is removed.
Old Jun 28, 2010 | 11:10 PM
n8ech's Avatar
n8ech
01ss:
The 8.25 rear end in my 04 has a rubber plug installed into the cover that the watts linkage attaches to.
BTW, my factory service manual says the 8.25 axle requires 70 ounces of gear oil.
I have yet to see an axle assembly without either a rubber fill plug, or a metal threaded plug somewhere on the side of the pumpkin so levels can be checked.
Either Mobil 1 or Royal Purple work very well.
Don
Old Jun 28, 2010 | 11:53 PM
01ssreda4's Avatar
01ssreda4
This is the 9.25 rear. Sorry, should have mentioned that.
Old Jun 28, 2010 | 11:55 PM
Dodge4lyfe's Avatar
Dodge4lyfe
actually, a diff can be filled without having a plug...They make special bags that you fill with oil and put inside the diff housing, and when you drive the gears puncture the bag and it disintegrates into the oil, and it's the proper level.
Old Jun 29, 2010 | 12:09 AM
n8ech's Avatar
n8ech
Make that 72 ounces for your 9.25 axle.
Dodge4lyfe:
Gotta say that I have never heard of that type of fill system for an axle. Sounds like something the engineers cooked up to please the bean counters.
Similar to the transmissions made that have no dipstick. Aka, Chev Mailbu, Pontiac Grand Am, and Olds Alero.
IMO, a vehicle component that costs 2 grand or more and relies on lubrication should have a freakin dipstick.
Don
Old Jun 29, 2010 | 12:46 AM
01ssreda4's Avatar
01ssreda4
Add mid/late 90s cavaliers to that list of no dipsticks.
Old Jun 29, 2010 | 04:03 PM
RedStrapperRacing's Avatar
RedStrapperRacing
01ssreda4 - here is all the info you need on capacities and Big_Wheel is dead on correct here - there is a rubber FILL Plug in both the front and rear diffs. I was just under mine a couple nights ago scoping it out before I swap out the OEM factory fluid with AMSOIL.
CAPACITIES: Engine, with filter..........7 quarts
Cooling System, Initial Fill..........16.3 quarts
Automatic Transmission, 42RLE Initial Fill..........4.1 quarts
Automatic Transmission, 545RFE 2WD Initial Fill..........5.5 quarts
Automatic Transmission, 545RFE 4WD Initial Fill..........6.6 quarts
Automatic Transmission, Total Fill
5 speed 545RFE 2WD..........14.1 quarts
4 speed 42RLE..........8.8 quarts
5 speed 545RFE 4WD..........14.1 quarts
Differential, C205F Front..........3.6 pints [2]
Differential, With 8.25 RingGear Rear..........4.3 pints [3]
Differential, With 9.25 RingGear Rear..........4.5 pints [4]
Transfer Case, NV144..........1.7 pints
Transfer Case, NV244 GENIII..........3.4 pints
[2] Fill to level of fill plug.
[3] Fill no higher then 1/4 inch below plug hole.
[4] Fill no higher then 5/8 inch below plug hole.
TORQUES: Oil Drain Plug.....25 ft/lbs
Transfer Case
Fill Plug 15-25 ft/lbs
Drain Plug 15-25 ft/lbs
Old Jul 2, 2010 | 11:41 PM
Big_Wheel's Avatar
Big_Wheel
ive heard of doing this if your on the trail and need to drain your fluid and need to put it back in with a zip lock bag--- but as soon as you get home or out of the trail you drain and pick all the pieces of plastic out..
i've googled the **** out of this and cannot find any special bag.
If you have a link or vehicle diff that uses this method please pass it on.
btw according to the service manual for both the 8.25 and 9.25 diffs there is a push in type plug
