2nd Gen Durango 2004 - 2009
2004 Hemi Durango -Poor acceleration and odds issues
Old Apr 19, 2011 | 07:50 PM
RangoStar's Avatar
RangoStar
Default 2004 Hemi Durango -Poor acceleration and odds issues
Hello,
My 2004 Durango Hemi, just did the spark plugs and EGR valve, I noticed in the last few weeks a loss of power when accelerating, just like if I was constantly pulling something behind the truck. Sometimes it's fine, some oter times, it's bad.
Also notice my temperature gauge is reading a bit higher than normal, gas mileage dropped big time (usually 15-16L per 100km in town, now i'm above 21L)
Don't know if this is associated with it, it developped a clicking noise on passenger side when the motor is cold, can hear it in the cabin. If it runs for 2-3 minutes, no noise when i'll accelerate. I have 2000 kms before my factory 7/115km expires, should I be concerned?
What could it be related to my issues? Bad fuel filter? Cat converters?
Old Apr 19, 2011 | 11:54 PM
n8ech's Avatar
n8ech
RS:
Sounds like you have the fabled exhaust manifold leak usually caused by broken or loose bolts.
what does your 7yr 115K warranty cover? is that the equivlent of the 7/70 powertrain warranty we had here in the US?
Your temp gauge should rest a needle width or two below the half way mark.
Has the cooling system ever been serviced?
Don
Old Apr 20, 2011 | 06:27 AM
RangoStar's Avatar
RangoStar
Yes, it's the equivalent of the 7/70 in US. My warranty ends in July of this year or 115,000km. I have 113000 now.
Would the thicking noise go away when vehicle has warmed up a bit?
Needle reads a titch lower than the half mark, all my cars i've had were like that but always thought the Durango's reading was cooler.
Should I call my Dodge dealership for those exhaust bolts? Would that cause poor acceleration and gas mileage.
Old Apr 20, 2011 | 08:03 AM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
I agree that the manifold studs are probably broken,
FF
Old Apr 24, 2011 | 09:11 PM
RangoStar's Avatar
RangoStar
My dad also thinks it's the studs that are broken.
Going in this week at the dealer, only 900 kms before end of warranty. Hopefully, it will be covered.
Old Apr 24, 2011 | 10:55 PM
n8ech's Avatar
n8ech
Rango:
Yes, an exhaust leak is usually indicated by a ticking noise that lessens or goes away as the engine warms up.
Let us know how this goes for you. Here in the US, the PT warranty would cover the manifolds themselves along with seals and gaskets. I do not believe it will cover broken hardware though.
I'll cross my fingers for you!
Don
Old Apr 27, 2011 | 08:07 PM
RangoStar's Avatar
RangoStar
Thanks!
I have an appointment tuesday, he wants it overnight as he can diagnose it properly. I told him that just by being off for less than an hour, they would ear the noise.
He said that if the bolts are broken, they will replace the whole manifold as it will be warped.
Old May 3, 2011 | 08:21 PM
RangoStar's Avatar
RangoStar
Studs AND manifold on passenger side was replaced today under warranty. Great to have that warranty. Almost made it out of warranty, i'm 300kms away.
Old May 5, 2011 | 11:02 PM
n8ech's Avatar
n8ech
Glad to hear this..... I assume the repair cured your issue?
Old May 9, 2011 | 05:46 PM
RangoStar's Avatar
RangoStar
It did! Now it's running like a champion.
