2nd Gen Durango 2004 - 2009
Replacing headlight bulb 2004 Dodge Durango
Old Oct 13, 2012 | 11:32 AM
LittleRiver2010's Avatar
LittleRiver2010
Default Replacing headlight bulb 2004 Dodge Durango
Can I replace the headlight bulb, of a 2004 Dodge Durango Limited, through the trap door in the wheel well, or do I need to take off the headlight assembly?
Thank you.
Old Oct 13, 2012 | 05:03 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
this needs to be in the 2nd generation section, ill move it there for you
Old Oct 13, 2012 | 06:23 PM
LittleRiver2010
So the moderator knows what generation it is, does that moderator know if I can change the bulb from the trap door in the wheel well?
Old Oct 13, 2012 | 07:06 PM
tattoohead's Avatar
tattoohead
This video might help:
Old Oct 13, 2012 | 08:26 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
You can change the bulb from the trap door although it is only to loosen a nut that holds the light assembly in the back. Under the hood there are two (or four) more nuts on top to complete the job.
FF
Old Oct 13, 2012 | 08:31 PM
1969CoronetR/T
vaffanculo
The video from tattoohead is not applicable to our generation only to the first generation Durango / Dakota.
FF
Old Oct 14, 2012 | 08:48 AM
MIKEon22s's Avatar
MIKEon22s
It can be done if you have very small hands and the tire is out of the way. You have the 10mm nut in the back to get out as well as the 2 above the light and 2 below the light. Then it has 2-3 ball and clips that need to be popped apart.
Old Oct 15, 2012 | 12:08 PM
kkpjm's Avatar
kkpjm
After a little investigation, I found the easiest method was to use the trap door and remove the nut on the back, then move to the front and rmove the (2) bolts below the headlight, using a long socket and extension. The trap door is great for the smaller handed folks, I could get a hand on the bulb back, but couldn't turn it. Going at it from the front was MUCH easier...I just did it this past weekend.
Old Oct 16, 2012 | 06:12 PM
LittleRiver2010
Thanks to every one for your replies. Guess the "bulb removal only" idea is out, and the headlight assembly removal idea is in.
LittleRiver
Old Oct 21, 2012 | 01:04 PM
Challenger383's Avatar
Challenger383
pain in the ***, best way is to remove the whole unit takes about 15 mins at most from start to finish
