2nd Gen Durango 2004 - 2009
2005 dodge durango tune-up tranny flush questions
Old Nov 19, 2012 | 12:33 PM
purplepills's Avatar
purplepills
Default 2005 dodge durango tune-up tranny flush questions
I am going to tune up my wife's 05 dodge durango. It is a 4.7 with about 170k on it. Here are my questions.
What plugs are suggested?
Is it easy to do the tranny flush (it is a 4wd)?
What else should I change/check during this tune up?
I am changing the oil, which weight/brand is recommended (I live is Cali).
Any insight, tips or advice is well appreciated.
Old Nov 26, 2012 | 11:41 PM
master tech's Avatar
master tech
Site Moderator & Tech
Well new guy
The spark plugs, i would champions. The transmission, don't flush the transmission. Because your transmission has a thermo block between the radiator and transmission. Replace both filters and add 7 to 10 qts of atf+4 and seal the pan with RTV sealer. By removing the filters. That will drain the fluid from the torque converter and pump.
Old Dec 18, 2012 | 09:03 PM
ndtguy's Avatar
ndtguy
My write-up.
https://dodgeforum.com/forum/2nd-gen...wap-today.html
If you have any questions, pm me.
