2nd Gen Durango 2004 - 2009
2006 Durango trans problem?
Old 01-16-2013 | 04:42 PM
Perch Eater's Avatar
Perch Eater
Default 2006 Durango trans problem?
Hi everyone im new to this site I need some help.I have 2006 durango with 54,000 miles on it and I just started having a problem with I think might be the trans.Between 30-40 mph the truck starts to shake when shifting I have been searching everywhere for an answer.Ive been on other sites where people say they had the same issue but know one seems to know what it is.Can anyone help with this issue?Have you had similar problems?Thanks in advance.
Old 01-17-2013 | 12:50 PM
DodgeCares's Avatar
DodgeCares
Perch,
What motor is in your D? Is it all wheel drive? Let me know and I will check for any service bulletins on the issue.
Welcome to the forum.
Old 01-17-2013 | 05:36 PM
Perch Eater
4.7 v8 awd/4wd
Old 01-22-2013 | 07:49 AM
DodgeCares's Avatar
DodgeCares
Perch,
I could not locate any service bulletin for the issue as you describe. The only mention of vibration had to due with the AWD system when uneven tire wear is experienced. Nothing mentioned about when shifting. Sorry I could not find more.
Old 02-02-2013 | 01:16 AM
ndtguy's Avatar
ndtguy
How does the transmission fluid look/feel/smell? Has it ever been changed out? Is there enough fluid in there?
Old 02-07-2013 | 05:22 PM
Perch Eater
just had it flushed and its still doing the same thing.I cant figure it out no check engine light and when its in tow mode it wont do it either.Only when its in overdrive it seems like its not shifting right or too early.
Old 02-09-2013 | 12:25 AM
ndtguy's Avatar
ndtguy
Are you sure that they put atf+4 in the trans. If not, get it out asap.
Also, how did they flush it? The only way that they could have done that is IF you have the tow package, they could use the lines to the trans cooler. Otherwise, the pan on our Durango (same setup as yours) does not have set of ports to hook up a flush machine.
Best bet is to drop the pan, replace both filters and fill the trans up with atf+4 (6 quarts).
Old 02-09-2013 | 11:54 AM
Perch Eater
Pep boys did it flush the whole system.I do have a tow pkg.Idid get the trans filter changed.
Old 02-09-2013 | 08:34 PM
n8ech's Avatar
n8ech
PE:
The 4.7 L engine uses a TPS or throttle position sensor that is attached to the throttle body. If/when this malfunctions, it can cause erratic trans operation big time.
Three screws hold it on, and you can install the new one easily.
I would give this a try as it may be the remedy to your issue. Another telltale sign of a bad TPS is the convertor locking/unlocking when using cruise control on flat land. You will see the RPMs jump up and down a couple hundred if this is the case.
Don
Old 02-10-2013 | 11:27 AM
Perch Eater
Originally Posted by n8ech
PE:
Don
Wouldn't a check engine light go on if the tps was bad?
Quick Reply: 2006 Durango trans problem?
