2nd Gen Durango 2004 - 2009
Need some advice I have 2004 d Durango 4.7 limited 4x4
Old Apr 30, 2023 | 06:25 PM
Jordan236's Avatar
Jordan236
Default Need some advice I have 2004 d Durango 4.7 limited 4x4
What years can I swap with my d and what to look for when doing this will a flex fuel engine2006 Durango also jeep believe it was a liberty will any of these work in its place do i need it's ecm and wiring harness and how to tell if engine is in good condition I can turn both engines with w socket fills like some compression problem in it would head gasket or the rings need changed also how to check the timing correctly if any one has information it be appreciated for some thank you
Old Apr 30, 2023 | 06:34 PM
What's wrong with the current engine??
Old Apr 30, 2023 | 06:59 PM
Jordan236's Avatar
Jordan236
The current one sent piston rod # 3 through the wall
Old Apr 30, 2023 | 07:20 PM
Ooops. Yeah, thats pretty much a fatal flaw.
Not sure there are any differences between the engines that will do the flex fuel thing, and those that won't. I believe that's just a matter of programming, and an additional sensor or two. Need to see how many connectors you have on your PCM, and make sure the engine you get used the same. The one difference I am aware of, is the tooth count of the tone ring for the crank sensor. They MUST match, else it simply won't run.
Moving this to 2nd Gen Durango section for ya. Folks there will know more than I do.
Old Apr 30, 2023 | 07:57 PM
Jordan236's Avatar
Jordan236
So they do have same amount of pugs to the ecm and also look the same everything just was thinking I might have to change some things like the fuel line new fuel pump things in that nature bring the computer with it what do I need to do yeah I'm getting this at a pick-a-pull and I went around and I turn the motors checked everything that I could check or possibly think of but also I'm kind of worried about this mounting bracket or something like that they are calling for her on these 4.7
Old Apr 30, 2023 | 09:28 PM
Well, you still have your original motor, right? Should be able to transfer anything you don't have from the old motor, to the replacement.
Old Apr 30, 2023 | 10:40 PM
Jordan236's Avatar
Jordan236
Yes I do but how do I tell if the engine is bad or going bad Any idea on that
Old May 1, 2023 | 10:56 AM
Buy one that you can hear run first, or one that has some variety of warranty... so if it does have problems, you have some recourse. Either that, or buy one cheap, rebuild it first, then install it.
