Biggest rim size on SXT??
RE: How about for a Change Bigger Tire Size
I would definitely go with 17inch rims and a 205/40/17 tire setup. It doesn't rub on the wheel well and your speedometer BARELY changes. Then you can have it lowered and not have your car look like its 3 feet in the air haha. I saw a ford tauras with huge rims and it looks sooo bad because it was like a foot off of the ground
Right, thats what I was saying. With that setup it barely changes. The more you go off of the originally tire+rim size the more it changes. The 205/40/17 setup will read 59 if you are going 60 which is not bad at all. The bigger you go the slower it will read I believe.
