who has most hp
Old Apr 26, 2007 | 06:25 PM
mikesxt's Avatar
mikesxt
Default who has most hp
just wondering what u guys are at hp wise. i wanna know mostly all motor no turbo....i wanna get it as close to 200 horses without turbo think its possible
Old Apr 26, 2007 | 07:06 PM
tooslow's Avatar
tooslow
Default RE: who has most hp
yes it is possible but it will cost twice as much as most turbo setups.
Old Apr 26, 2007 | 07:51 PM
contagious19's Avatar
contagious19
no braggin rights for me, i only got 145
Old Apr 26, 2007 | 08:12 PM
l_pillon's Avatar
l_pillon
im bone stock....u dont want none of me lol....smoke ya off the line hahahahahah
Old Apr 26, 2007 | 08:55 PM
03neonRT's Avatar
03neonRT
ORIGINAL: mikesxt
200whp on a 2.0 wont be a streetable car...nor will it be cheap. Heres a basic list for a 200whp N/A 2.0L Neon...
Forged pistons (12.5+ compression)...{you'll need to run 100+ octane at all times as well}
Forged connecting rods
MagnumHead race portedand deckedto the max.
Knife edged and lightened crank
Race balanced and blue printed block
Over sized valves, titanium valve springs, retainers...
Crane #005 (#16)cam
AEM Adjustable Cam Gear (with timing advanced 4 degrees or so)
Custom "box" intake manifold
Longtube header
60mm-65mm TB
Cold Air Intake
2.5"-3" full exhaust
MSD Coilpack
MSD Wires
Denso iridium plugs (hotter)
Full standalone (MSnS)
A LOT of dyno tuning since you'll need to rev to 9k+
Good clutch and torsen differential
UDP with P/S and A/C removed
ORIGINAL: contagious19
With the mods listed in your sig, you probably have more like 115whp...plus the big 17" wheels are only slowing you down and throwing off your gearing.
I probably have close to 145-150whp with the mods I have, if that...
Old Apr 26, 2007 | 09:10 PM
AirWolf's Avatar
AirWolf
I proabably have at least 150 hp with my new engine mods or a little more than that .
Old Apr 26, 2007 | 09:11 PM
03neonRT's Avatar
03neonRT
What are your engine mods AirWolf?
Old Apr 26, 2007 | 09:24 PM
AirWolf's Avatar
AirWolf
Well the mods I just got not to long ago are mpx 60mmtb,walbro highflow fuel pump,mpx underdrive pully,aem ajustable cam gear,msd coilpack, just changed my wires to msd ones and i have platiunm plugs said I would never change but I did changed over to champions for the plugs I have a custom cold air not short ram intake also my srt exhaust with glasspack vibrant front strut bar and will have race red motor mounts . so how much hp do you think all this should get me and Im still stock with 15inch rims but wider tires .
Old Apr 26, 2007 | 09:35 PM
03neonRT's Avatar
03neonRT
ORIGINAL: AirWolf
The only engine mods you have that would actually "add" power are the 60mm TB, custom CAI, and UDP. The adjustable cam gear is worthless without a Crane 14 or larger cam, the plug wires only help with a smoother idle, and the coilpack and fuel pump wont do anything without serious engine mods. The motor mounts and wider tires will help with traction, but not add any power obviously. The SRT-4 exhaust doesnt really add any power either, since its not much less restrictive then the stock SXT exhaust system...so your prbably still looking at 115whp maybe a little more.
Old Apr 26, 2007 | 10:42 PM
2003SXTneon's Avatar
2003SXTneon
Whats the stock Hp for sxt and the r/t?
I think the r/t is @ 150.
Question was hp for non turbo, whats the hp for the neons out there that have turbo. I know we gota couple on this forum.
