2001 Neon stumbles on acceleration
Old Apr 28, 2007 | 02:39 AM
neisg1's Avatar
neisg1
Default 2001 Neon stumbles on acceleration
2001 Neon ATX 105,000km , stumbles on acceleration, intermittently has check engine light on with code P0302. cylinder # 2 misfire.
Is this code generally related to plugs and wires? Or could injectors be an issue?
Old Apr 28, 2007 | 05:47 AM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
Default RE: 2001 Neon stumbles on acceleration
plugs and wires may be a very good place to start. crappy spark may definately give you a bit of a sputter. and for a few bucks a bottle of injector cleaner couldnt hurt anything.
btw, how old are your current plugs / wires?
Old Apr 28, 2007 | 06:14 AM
neisg1's Avatar
neisg1
ORIGINAL: flamingpinhead
Yea, I thought I would start with the plugs and wires plus injector cleaner. It’s my daughters car and I’m pretty sure the wires are original the plugs I’m not sure about.
Old Apr 28, 2007 | 08:33 AM
lblackneon's Avatar
lblackneon
It's either this or a dirty air filter.
Old Apr 28, 2007 | 09:45 PM
kayakman's Avatar
kayakman
Look in your intake manifold for oil.
Old Apr 29, 2007 | 07:01 AM
flamingpinhead
Section Moderator
105,000km, roughly 65244 miles... if those are the origional plug wires than they need replacing. plugs right along with them... and if the air filter is ancient, dear lord. for the price the K&N air filters are well worth it, youll probablynever need to buy another air filter for it.please dont take it the wrong way butplease doteach her a bit about auto maintenence so she isnt another helpless chick.
Old Apr 29, 2007 | 07:17 AM
neon03se's Avatar
neon03se
more than likely your plugs and wires. my car was doing this same thing and that fixed the problem. however my mechanic did replace my coil pack just so that i could have new parts,and as everyone says, you should change your air filter
Old Apr 29, 2007 | 04:44 PM
neisg1's Avatar
neisg1
Thanks for all the comments.
I looked it over a bit and the air filter appears to benew she says it was just changed. The plug wires look OK but are original so she's going to pick up a new set as well a new plugs (also original?). I put some injector cleaner in it yesterday so we'll see if that helps (can't hurt).
