Front Brakes for 2001 Neon
Old May 13, 2007 | 11:33 PM
rm5830's Avatar
rm5830
Default Front Brakes for 2001 Neon
Hey, I have had two people tell me that you can put srt-4 front brakes on a 2001 and up neon. Is this true? And if it is true, then the wilwood big brake kits made for 2003 and up srt-4's should fit my car right? And if it does not directly bolt up, what can I do to make a big brake kit fit my car? Or is there a company that sells a direct fit for my car?
Old May 14, 2007 | 12:45 AM
ewetho's Avatar
ewetho
Default RE: Front Brakes for 2001 Neon
You need new knuckles and then compensate for the knuckle steering arm position and shorten the inner tie rods or get a SRT rack.
Some have used PT GT knuckles (i think it was) look around for the people who put SRT brakes on and you will see what you need.
Old May 14, 2007 | 03:33 AM
djmagic's Avatar
djmagic
Yeah I would think it would be easier just get a new hubs and also you have to change the steering rack too. But do the back ones to because big brake in the frontand stock in the back doesn't look right, spells civic
Old May 14, 2007 | 08:50 PM
Izero's Avatar
Izero
if you wanted to use the wilwoods you might need a larger Master Cylinder too but im not sure about that.... it all depends on what size the calipers are.... and you also have to take into consideration that the SRT4 has 17" rims which have the space needed to fit those bigger brakes in there... just a thought, correct me if im wrong here....? but unless you are using your neon for some serious race applications you shouldn't need to change the brake calipers.... you can just go with drilled and slotted rotors, and match those with a nice exspensive set of compound brake pads, but my bet is that if you do that you are just asking for the ABS to go wild when you are just driving around down and someone stops short in front of you..... the ABS on neons can be kinda sensitive sometimes.... well at least on mine it can be sometimes haha
Old May 14, 2007 | 09:32 PM
rm5830's Avatar
rm5830
Awesome, all that info really helps, Yeah Im putting serious power down with the neon, about 25grand put into it, crate motor with ultra performance bottom end, crane 12 grind, everything internal is forged, 75shot wet kit of the zex, and every bolt on possible. And when I do the road race in town, my brakes almost catch on fire, oh the smell that produces. Thanks again for all you guys help, i will check it out.
Old May 14, 2007 | 09:35 PM
Izero's Avatar
Izero
ok well your going to have to prolly re-do the whole brake system if thats what you are doing..... and 25 grand!? please god dont you dare tell me you are running an N/A setup....... b/c for 25grand you might as well buy yourself a brand new WRX or Evo or something else that will give you fairly less exspensive results..... but hey if your already on your way with it good luck and dont kill yourself with that 75 shot...... and post some pics! ASAP!
Old May 14, 2007 | 10:21 PM
03neonRT's Avatar
03neonRT
Yeah I'm not seeing how you spend $25,000 on a built engine and go with a Crane 12, only bolt ons, and only a 75 shot on a built bottom end with stock PCM running engine management...but thats just me.
Old May 15, 2007 | 03:55 AM
Izero's Avatar
Izero
i thought i was the only one that thought that... i mean maybe "2.5" or 5g's max but who knows....
Old May 15, 2007 | 04:17 AM
lblackneon's Avatar
lblackneon
Reading that comment is pretty funny. 25 grand seems a bit high but good luck with everything.
Old May 15, 2007 | 04:44 AM
djmagic's Avatar
djmagic
Well I want to drop more than that with the SRT-4 Engine, tranny and Mopar Stage 3 turbo kit. But thats just me
