Help Installing Black rojector Headlights
Old Sep 18, 2007 | 06:32 PM
NeonBabyRns's Avatar
NeonBabyRns
Default Help Installing Black rojector Headlights
Hey guys I just bought some new black projector headlights
http://cgi.ebay.com/ebaymotors/ws/eB...161773414&rd=1
I didn't get instructions and I'm not quite sure how to do this. Does anyone have these, and does anyone have like the instructions to them?
Thanks sooo much, could use these instructions ASAP!
thanks
Sam
Old Sep 18, 2007 | 06:35 PM
AirWolf's Avatar
AirWolf
Default RE: Help Installing Black rojector Headlights
Hey just pm mikey he has the same headlights installed on his 04 sxt . Hes spikey mikey has the coolest sxt on here until next yr .
Old Sep 18, 2007 | 06:36 PM
night709's Avatar
night709
What wires came attached to the lights? How many of each and what colors?
Old Sep 18, 2007 | 06:44 PM
night709's Avatar
night709
Mine came with 2 white wires, 2 red ones, and 2 black ones. The whites ones, unless you want them ran when you turn on your actual light. They should be ran to a switch because they control your rings and 3 LED's on the side. The black are bolted to the car and the reds go to the battery. Hope that helps you out. If they are like the ones I have.
Old Sep 18, 2007 | 06:49 PM
AirWolf's Avatar
AirWolf
Ive got to get me some of those projectors the ones from modern are a bit cheaper guess I will be getting some eventully from them maybe .
Old Sep 18, 2007 | 07:21 PM
night709's Avatar
night709
I spent like $150 shipped for mine.
Old Sep 18, 2007 | 07:31 PM
spikeymikey87's Avatar
spikeymikey87
ORIGINAL: AirWolf
lol damn straight.
ok the actual headlught bulbs are plug and play, but for the halos and the 3 side leds, you have a few choices on what to do. you can have them on all the time when the running lights are on, you can have them blink with the blinkers, or you have have a combo. personally, i have the halos on with the running lights and the 3 leds with the blinkers. to do this you are going to have to splice into the turn signal wiring harness. if you look, there are 3 different wires on the turn signal harness. there is a black one, then 2 other ones. the solid black is the ground where you should splice all the black wires from the headlight into. i dont remember which one the other ones goes to, so you will have to check which is the turn signal and which is the running lights. oce you figure out what you want where, just splice into the wires. theres 1 white wires for the 3 leds and there are 2 white wires for the halos
any other questions, just ask
Old Sep 18, 2007 | 07:39 PM
AirWolf's Avatar
AirWolf
ORIGINAL: night709
maybe if yours was a 00-02 neon but a 03-05 neon cost like close to 300 bucks and 250 shipped from modern .
Old Sep 18, 2007 | 07:43 PM
AirWolf's Avatar
AirWolf
ORIGINAL: spikeymikey87
ORIGINAL: AirWolf
lol damn straight.
You may have the nicest sxt this yr but wait till next yr mine will be all different by next yr and hopefully with a kit and vertical doors and rims and tires and different graphics and an airride all in the works for 08 and turbo .
Old Sep 18, 2007 | 08:16 PM
Adionik's Avatar
Adionik
ORIGINAL: AirWolf
lol damn straight.
y r u so slow?
