SeaFoam
RE: SeaFoam
I have used Seafoam on many cars that I have owned. I usually use about 1/4 bottle in the brake booster line to suck it into the engine. Let it sit for 15 minutes and drive it around unitl it stops smoking. Another 1/4 in the gas and another 1/4 in the oil.
You should change your oil after you put seafoam in it. I have heard it will kill the oil's viscosity and could cause damage if you don't change your oil after using it.
RE: SeaFoam
I have used it before I don't think I will ever again...I didn't put it in the crank case because I didn't want to change my oil and I heard if you pour it in there then you gotta change it. But I put it through the PCV line and the gas tank. My car sometimes studders(kind of like a misfire) when I accelerate. Its very slight though. After I put the seafoam in it went away completely. I had no problems at all and it was very smooth. About a week later it all came back again...My car is how it was before the studdering...I just lost 5 bucks, thats the only difference lol.
I guess you are supposed to use it like every 3000 miles though. I also heard some people say it made them get insane mileage and then went away after a week.
EDIT: Oh yeah, and definitely believe it when it says don't use after 150,000 miles lol. My uncle used it in his van through the gas tank. It broke up a lot of build up and it ruined his fuel pump lol.
