Trans swap
Old Nov 15, 2007 | 10:58 AM
  #51
Kalevra's Avatar
Kalevra
Default RE: Trans swap
[/discussion]
Old Nov 15, 2007 | 12:00 PM
  #52
Pharmboy's Avatar
Pharmboy
ORIGINAL: Sawhiskey
Yea Yea Yea
Edit: I think the link that Graphite posted takes care of any questions and just proves you wrong pretty much. Check it out.
please explain, that link applies again to doing it yourself, which is NOT what I am arguing.
Old Nov 15, 2007 | 12:08 PM
  #53
Kalevra's Avatar
Kalevra
ORIGINAL: Pharmboy
ORIGINAL: Sawhiskey
Yea Yea Yea
Ok, so, what is the total cost of a trans swap in a neon? if you get your parts at a nice happy $500
EDIT: if you think we're so wrong then prove it! and dont pull a number out of your ***. how many hours will it take?
Old Nov 15, 2007 | 02:34 PM
  #54
Sawhiskey's Avatar
Sawhiskey
Well I will agree with you on one thing. Getting a shop to do the trans swap is just ludacris, unless you have a friend or something.
Old Nov 15, 2007 | 05:50 PM
  #55
GrApHite03's Avatar
GrApHite03
ORIGINAL: Sawhiskey
when i move, you move! just like that....
Old Nov 15, 2007 | 06:28 PM
  #56
Kalevra's Avatar
Kalevra
here we go again
Old Nov 15, 2007 | 07:47 PM
  #57
2004neonR/T's Avatar
2004neonR/T
So since were talking about swaps and everything lemme jsut ask a real quick question....Will a srt-4 trans fit my 2.0 block?????
Old Nov 15, 2007 | 08:11 PM
  #58
dodgeneonz's Avatar
dodgeneonz
Well, I did the research a while ago and here's the approx. realistic price quote without labor... from what i can tell it's approx 350-400 just for the mtx transmission itself with the PCM... i found a transmission for 65k miles for approx 230, and then the pcm from what i can find is all approximately 80 - 100... and we're talking about used items here. Add in the fact that you need to find clutch and cables and etc... which is probably gonna be about couple hundreds unless you get really lucky to find some that's dirt cheap. After that... if i'm not wrong (correct me if i'm wrong) you'll have to cut a hole in the chasis for the clutch pedal if you have atx. So if you're going NA for the long run then it's a good investment. As for me, i'm saving those toward one of those srt engine with transmission combo swap.
Old Nov 15, 2007 | 08:23 PM
  #59
GrApHite03's Avatar
GrApHite03
no hole needed, its all ready there...
Old Nov 15, 2007 | 08:44 PM
  #60
dodgeneonz's Avatar
dodgeneonz
really? dang... that could've been my motivation factor to get the mtx last time... i was so close to getting one... but then gave up because of the price and the fact that i have to cut a hole... which i don't have the know how or the equipment... but dang... maybe i should reconsider getting the mtx [sm=devilgrin.gif]
