Couple friends of mine are thinking about going on a road trip. And while my friends RSX is a hell of a lot better built than mine...i'm wondering if i can trust this car on a long drive. My RPM's fluctuate when I have the AC on, any reason you guys think it might do that?
Aside from that, what precuations should be taken to ensure my car doesn't explode on the way over there? I figure I would flush tranny fluid, change oil, clean k&n, and put the stock muffler back on
i like myself so much i double post in my own threads
LOL before a road trip i always check all fluids and tire pressure. if i its been a while since i changed sometin, then ill change it a couple days before da trip.
im taking a 700 mi 10 hr trip to see my girl. and I'm wondering the same. I have faith in my ride and I think she can do it, as long as I change the oil before hand and the trans (needs it anyway)
Ive taken alot of road trips in my 04 sxt thats why she has the miles on her like she does. All we do is change the oil and check the fliuds and were set.
Do it. I've done it with my neon several times. Hasn't let me down yet, it has been very dependable. Like others have said just make sure fluids are all good and you don't have any problems that you know of before you leave. Long as you are up on regular maintenance you should be set.
i took a 16 hour trip in my neon from ohio to florida when i moved down here my parents had to fill up 2 times before i filled up one time bro so the neon is a better choice then the RSX bro
but ya check all the fluids and tire pressure and you will be set
