NeonOn19s Project thread
Old Jan 24, 2009 | 11:58 AM
  #311
NeonOn19s's Avatar
NeonOn19s
Well last night I picked up my buddies high speed buffer and another Turbo housing to work on. I used a 3 stage polishing setup, and worked on it last night for a couple of hours and then finished it up this morning for now...
BEFORE:
AFTER:
THE COMPARISON BETWEEN THE TWO:
I also started on installing the adapter plate, but ran into a small issue.
This is only the half of the adapter and I have a some play even with bolts tight. I might have to change out the bolts to a shorter one, I might be hitting the end of the thread. I took a break ( its 50 out and a bit cold for us southerns)
I should put more up later on today.
Old Jan 24, 2009 | 03:10 PM
  #312
NeonOn19s's Avatar
NeonOn19s
Well I tried again after I had some lunch and figured that I was using the wrong size of bolts, there were 3 differnt sizes to the kit and I put the wrong ones on first.... .
So I finished mounting the adapter plate up to the block.. Looking good so far...
I then did a test fit with the Turbo manifold on to check clearances..
I think that I need to cover up the lines attached to the firewall..
I will mess with it more in a bit.
Old Jan 24, 2009 | 06:48 PM
  #313
djmagic's Avatar
djmagic
Ooooo, shiny turbo....needs to be donated to Djmagic....lol. 19's I might have to send you some parts to make shiny since you do such a great job. With those frequent flier miles out to DTJ, you can use some to flyout to Tucson and shine some parts.
Old Jan 25, 2009 | 09:53 PM
  #314
NeonOn19s's Avatar
NeonOn19s
no problem man.. send it my way and we can work something out...
Old Jan 26, 2009 | 07:45 AM
  #315
dtjackten's Avatar
dtjackten
2nd gen neon peace keeper
looking good, i am ordering my turbo today for my car.... should be about three weeks till i see it however..... sucks they have to custom make it!!! did not touch my car much yesterday, just set the intake in place, besides that nothing really.... maybe mount the radiator in today or just look at it today after work... one or the other, lol
Old Jan 26, 2009 | 09:22 AM
  #316
NeonOn19s's Avatar
NeonOn19s
lol....
I didn't even look at the car yesterday. watched the AllStars hockey and played a little COD5.
Old Jan 26, 2009 | 10:15 AM
  #317
dtjackten's Avatar
dtjackten
what did u use on the compressor housing??? i have used jewlers polish and that seems to work good, but does not hold up long.... my manifold looks like it needs some work already, shine does not hold up very well
Old Jan 26, 2009 | 03:06 PM
  #318
NeonOn19s's Avatar
NeonOn19s
I bought the 3 step polish bricks ( brown, black and white) and used it on my manifold and it worked great, so I figured that I would try it on the housing too.. If it doesn't work, then I send it out to get ceramic coated to keep the shine.
Old Jan 26, 2009 | 04:29 PM
  #319
dtjackten's Avatar
dtjackten
hey i am still waiting for ur check to clear???? what is up with that? haha, that was along time ago, i dont have ceramic coating around here. it sucks, so before shows it is going to suck cleaning my engine bay
Old Jan 26, 2009 | 09:29 PM
  #320
NeonOn19s's Avatar
NeonOn19s
Well times are tight... especally with the economy and all.. ceramic coating normally can be done by the powder coaters i thought.
