Prothane Motor Mount Inserts
Old Dec 1, 2004 | 03:09 PM
lblackneon's Avatar
lblackneon
Default RE: Prothane Motor Mount Inserts
85 ft. lbs? Is that on your SRT manual?
NeonSXT04, how many ft. lbs did u tighten your Prothane inserts?
Thanks guys
Old Dec 1, 2004 | 03:19 PM
LowSlowNeon's Avatar
LowSlowNeon
Its 85ft lbs for both.
Old Dec 1, 2004 | 06:25 PM
boosh's Avatar
boosh
i have a busted front motor mount... how much would a new one be from dodge?
or i could just get some inserts... problem fixed lol
Old Dec 2, 2004 | 03:57 AM
casper's Avatar
casper
The basics of it is this, tighten it enough that they won't come loose, they do hold the motor in place, and no too much that you break a bolt. I am sure that there are exact specs for every bolt on the car, but thats the easy way.
Old Dec 2, 2004 | 04:04 AM
LowSlowNeon
Well like RR said...its 85ft/lbs according to the FSM.
Old Feb 23, 2006 | 05:06 PM
Customlimitz863's Avatar
Customlimitz863
Here is where the proper wording is needed. Your motor mount inserts aren't actually for the motor mounts, they are for the torque struts, the torque struts simply keep the engines twisting and torquing in check. The inserts limit this movement even more. And the factory service manual calls for these bolts to be torqued to 85 ft. lbs.
_____________________________
71 Plymouth Roadrunner 440 Auto. Modified
04 Dodge SRT-4 2.4L DOHC Turbo Intercooled 5-spd. Modified
SO THAT BEING SAID...THAT MEANS MY O4 SXT NEON MOUNTS (TOP/BOTTOM) WOULD ALSO BE TORQUED TO 85ft/lbs???????
Old Feb 24, 2006 | 01:42 AM
casper's Avatar
casper
ORIGINAL: boosh
What part did you break? The bolt, braket, or the rubber?
