Prothane Motor Mount Inserts
Old Nov 29, 2004 | 06:09 PM
lblackneon's Avatar
lblackneon
Default Prothane Motor Mount Inserts
I have the Prothane Motor Mount Inserts (Race). I don't have the directions in front of me now, but, I was reading the directions on how to install them and I believe the directions said you have to torque them to a certain pressure. Tell me if I'm wrong, I think it said you have to refer to the service manual for that information.
I bought my car without thinking about the car manuals (later realizing I didn't have any[:@]).
I called Crysler corp (b'c the dealership said I might save a penny if I called them) and they said the service manual was 90.00 dollars and the owners manual was 15 dollars. I really don't feel like spending that money right now (especially because of Christmas).
Do you have to torque it/ tighten it to a certain amount?
Is there a special way I am supposed to do it (since the directions said to refer to the manual)?
Old Nov 29, 2004 | 06:27 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
Default RE: Prothane Motor Mount Inserts
call a dodge dealership and ask for the shop foreman.
Old Nov 29, 2004 | 06:49 PM
lblackneon's Avatar
lblackneon
Will I find out information that is in the service manual?
Old Nov 29, 2004 | 07:00 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
yes....i dont think the owners manual will tell you...
what is the year make and model? il find out for you what the stock torque setting is...
Old Nov 29, 2004 | 07:39 PM
lblackneon's Avatar
lblackneon
2000 Dodge Neon ES
I could have sworn it said to refer to the service manual though.
Old Nov 29, 2004 | 08:03 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
one of our "master techs" downstairs said that he would torque them to 40ish. he said that youll be "hard pressed to find a torque spec on a motor mount".
have you taken them out yet?
Old Nov 30, 2004 | 02:20 PM
lblackneon's Avatar
lblackneon
No I haven't taken them out yet. I was just reading the directions the other night. I am going to have someone else install them with a few other things.
Old Nov 30, 2004 | 02:34 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
heres what you do then..get a torque wrench...and set it to 30lbs see if ti clicks
set it to 40 lbs...see if it clicks...
then go to 45...see if it clicks...
like i said, the guy i talked to said 40ish should be adequate
Old Dec 1, 2004 | 12:06 AM
LowSlowNeon's Avatar
LowSlowNeon
they aren't hard to install...just make sure you support the motor slightly when you do it. I used a jack and a piece of wood and just put the jack enough to hold the motor while i could pull the bolt out and put the insert in and place the bolt back. The bottom mount you will have to take one of the plastic shields off to get at. The top mount is easy to get at. You should be able to handle the job in about 30-45 minutes I would think. Its not too hard.
Old Dec 1, 2004 | 07:51 AM
71RoadRunner's Avatar
71RoadRunner
Here is where the proper wording is needed. Your motor mount inserts aren't actually for the motor mounts, they are for the torque struts, the torque struts simply keep the engines twisting and torquing in check. The inserts limit this movement even more. And the factory service manual calls for these bolts to be torqued to 85 ft. lbs.
