engine codes help
Old Dec 29, 2007 | 04:43 PM
bone33's Avatar
bone33
Default engine codes help
ok, heres the deal.
i have a 2000 with a 5 speed 99,000 miles. 2750 miles since last oil change. i have not driven this car for 1 month. today i start it and it dies right away. i start agian, no problems, but the engine light is on.... i drive it like 5 miles and come home, i just wanted to take it for a spin. its popping two codes:
P0340 Camshaft Position Sensor Circuit Malfunction
P1684 Metering Oil Pump Position Sensor Circuit Malfunction
should i disconnect the positive side of the battery to reset the computer and see if it happens again?
what do these codes mean?
Old Dec 29, 2007 | 04:57 PM
turtletunes's Avatar
turtletunes
Default RE: engine codes help
p0340.. i just had this problem last week.. easy fix.. go to a local napa store or dealership and buy a camshaft postion sensor.. ranges from 30 to 40 bucks.. you can also go to this link and it will tell you where to find the camshaft postion sensor.. i did it in about a hour..
http://autorepair.about.com/library/faqs/bl968d.htm
Old Dec 29, 2007 | 11:51 PM
master tech's Avatar
master tech
Site Moderator & Tech
P0340 is for the cam sensor and P1684 is battery disconnect code. Replace the cam sensor and use a scanner and clear all your codes.
Old Dec 30, 2007 | 10:46 AM
bone33's Avatar
bone33
ORIGINAL: master tech
thank you.
