max boost??
Old Jan 10, 2008 | 04:55 PM
madcracker's Avatar
madcracker
Default max boost??
so i changed the fuel pump to 255 lph but rest of the fuel system is the same...anyone know how much boost i can run before im lean?? any help appreciated
Old Jan 10, 2008 | 05:00 PM
dtjackten's Avatar
dtjackten
2nd gen neon peace keeper
Default RE: max boost??
R u running bigger injectors too? , what about a return line system?? fuel pressure regulator?? if non of those are present, maybe two pounds before the computer shuts down.........
spikeymikey87's Avatar
spikeymikey87
well you should worry about teh internals not being able to handle the pressure first befpre talking about going lean. mayne 8 lbs safely i think. check the turbo sticky
Old Jan 10, 2008 | 05:06 PM
dtjackten's Avatar
dtjackten
10 lbs is the max on a GREAT tuned 2.0, eight is safe......
but if he does not have aftermarket injectors the fuel will not go in fast enough, and the injectors will shut off trying to dump more fuel in when into boost, causing the car to lean out before internal wear out
Old Jan 10, 2008 | 05:35 PM
madcracker's Avatar
madcracker
its 2005 srt4 stock injectors fuel rail, only thing changed is fuel pump
Old Jan 10, 2008 | 05:41 PM
tooslow's Avatar
tooslow
maybe you should ask in the srt section they will be able too help you
Old Jan 10, 2008 | 05:56 PM
lblackneon's Avatar
lblackneon
ORIGINAL: madcracker
The question should be, how much boost can I run before I break my internals. As far as running lean, that's secondary to your internals. It's hard to say when you'll start to run lean. It depends on your mods and your car. The best thing you can do is get a Air/fuel wideband gauge to see your air/fuel ratio.
Old Jan 11, 2008 | 01:12 AM
GrApHite03's Avatar
GrApHite03
You can turn it up until...
1. You max out your stock internals. Usually around 240-250wtq
and/or
2. You lean out from not enough fuel. I would not suggest running a A/F ratio higher than 11.5:1
and/or
3. Your EGTs get close to 1500 degrees. i would not suggest any hotter than that.
