Problem- Auto tranny
Was wonderring if there's anyone else who has an 04 SXT that has had issues with their auto tranny? Mine started to whine alittle bit a few days ago, just put it in the back of my head as the car was just cold... today it got alot worse and actually started to slip and whine real bad. Almost sounds as if a pump was bad??? Took all the lines off and make sure they were not blocked. So the fluid is moving... Gonna go pick up a filter and some new fluid and pray that helps it out! Anyone else with any input would be greatly appreciated!
I still have the power train warranty on it, so if the filter isn't the cause of it after I replace it then I'll have to bring it in...
Only have the one vehicle, so ifI can fix it this weekend it would be nice. If not, I'm screwed Monday!Was just hoping to hear maybe from someone who may have had something similar happen to their car?
Well it seemed to fix whatever was goin on for now??? Took the filter off, it did look inpretty crappy shape... Replaced the filter and refilled her back up and it stopped sounding like it was screwed up. Gonna have to keep an eye on it and the first sign that somethings wrong, I'll bring it in. Still have a bunch of miles on the warranty before it's up.I have a friend who works for a jeep dealership and he said that they would cover the remaining warranty on it. Told him what I was gonna do and he said ok as well, just to bring it in if anything gets worse again. Good to have friends who work at a STEALERSHIP!!! lol
Side note- the fluid was pretty crappy as well when i drained it... Not sure if someone before me was using the right kind of fluid when they were topping it off or not???
Trending Topics
ORIGINAL: neon03se
how hard was it to change the transmission fluid?
I put the front of the car up on ramps and used a creeper to work on. You could do it on the ground if you had to almost...
ORIGINAL: neon03se
ORIGINAL: srtgtr34
I would still try to bring it to a dealer as soon as you can and tell them your story, you may have just temparily fixed the problem.
Find out in the next few days or so... Least I know I have some time before the warranty is up when it goes!!!
