read the manual and buy urself a haynes repair book and read how-to drain and fill the trans.... if you do it urself it should cost u like $50-$60... and as for your third gear problem... u have to have the clutch engaged to put the car into ANY GEAR and if u let off before its in gear you will grind the gears its as simple as that so unless ur racing (on a track hopfully) take your sweet @$$ time and shift right.... no need to destroy your trans......
