Tire pressure
Old Feb 14, 2008 | 11:21 AM
gilligan's Avatar
gilligan
Default Tire pressure
Hi guys,
I have a Dodge Neon 2003 SXT. I'd like to know what is the tire pressure in cold weather for both front and rear tires. I checked the manual and it doesn't say anything about the tire pressure.
Thanks a lot for your help.
Old Feb 14, 2008 | 11:30 AM
ricerchik02's Avatar
ricerchik02
Default RE: Tire pressure
I believe its 30psi. Cold weather shouldn't make a difference, just the tires shouldn't be hot when you put air in to get an acurate pressure reading. The tire pressure required can be found on the sticker on your drivers side door when you open it, but I'm pretty sure its 30.
Old Feb 14, 2008 | 11:31 AM
AirWolf's Avatar
AirWolf
I always keep mine at 40 no matter what winter , spring ,summer or fall and thats front and rear tires. Really got to keep mine up since they are new they havent gone down any even during the winter.
Old Feb 14, 2008 | 11:33 AM
ricerchik02
Won't that cause uneven tire wear?
Old Feb 14, 2008 | 11:39 AM
AirWolf's Avatar
AirWolf
Says in my door 32 and where I got my tires they told me 40 is all the more I can do no more . I have yet the need to put air in my new tires . If I do my husband and I have out own air compresser.
Old Feb 14, 2008 | 12:24 PM
gilligan's Avatar
gilligan
Hi,
Thanks a lot for your answers. Guess I have to put more air!! I'm using an electronic air gauge. It should be acurate.
Old Feb 14, 2008 | 01:51 PM
djmagic's Avatar
djmagic
32 for normal and 35 for low profiles
Old Feb 14, 2008 | 01:57 PM
Kalevra's Avatar
Kalevra
I have Eagle LS's ir lx's or w/e in the factory size... 35 PSI is recommended
Old Feb 14, 2008 | 04:32 PM
AirWolf's Avatar
AirWolf
I guess for wider tires you have to keep more air in them. I have pretty wide tires now so thats what Im doing keepin anywhere from 35 to 40 in them .
Old Feb 14, 2008 | 05:43 PM
bone33's Avatar
bone33
some people dont know crap about tire pressures.
15 inch stock tires take 32 PSI and 14 inch stock tires take 36 PSI. there is a sticker on your door. FOLLOW that.
