HELP! HOW HARD IS IT TO FIX?
Old Feb 20, 2008 | 04:00 AM
ironeagle_1983's Avatar
ironeagle_1983
Default HELP! HOW HARD IS IT TO FIX?
WELL WITH THE HUGE SUBS I HAVE INSTALLED IN MY 05 NEON HAS TAKEN A TOLL ON THE ORIGINAL ALTERNATOR AND THAT BAD BOY IS NOT CHEAP! WELL MY QUESTION IS HOW HARD IS IT TO INSTALL A NEW ONE CAUSE I WOULD RATHER NOT PAY SOME ONE I'M AN OK MECHANIC BUT IF IT MEANS TAKING APART HALF THE CAR I WOULD RATHER NOT.
Old Feb 20, 2008 | 09:06 AM
Mat00ES's Avatar
Mat00ES
Default RE: HELP! HOW HARD IS IT TO FIX?
Im pretty sure the alternator is up top, if you can replace belts and undo bolts you should be all set.
Mat
Old Feb 20, 2008 | 01:14 PM
GrApHite03's Avatar
GrApHite03
The altenator is very easy to replace... you don't have to take half the car apart.
Old Feb 20, 2008 | 02:31 PM
03neonRT's Avatar
03neonRT
ORIGINAL: GrApHite03
Haha +1. I thought I posted a little how-to with some pictures on here a while back...but I cant seem to find my post...
Old Feb 20, 2008 | 05:05 PM
Undesolved's Avatar
Undesolved
TURN OFF THE CAPS LOCK ITS ANNOYING READING YELLING!
Old Feb 20, 2008 | 05:56 PM
Adionik's Avatar
Adionik
I would like to know as well as i'm doing the ODP install
Old Feb 21, 2008 | 09:53 AM
NHARINTON's Avatar
NHARINTON
Its easy and mine is on the bottom..... i just took my passenger wheel off and it took me abot 30min.
Old Feb 21, 2008 | 10:06 AM
Izero's Avatar
Izero
if you have subs that are too large for the alternator to keep the battery charged i would suggest you get an alternator that has a higher output so it will charge the battery.... i would also suggest a high farad capacitor in line before the amp.... if you have two amps i would suggest you get two....
Old Feb 23, 2008 | 12:57 AM
ironeagle_1983
thanks for the help im going to upgrade to a bigger altand change out the big 3... bigger wire from bat to alt from bat to frame and from engine to frame. then put a kintetic hc 800 amp battery in the trunk cause i going to install two solo x's and get a bigger amp. thanx
Old Feb 24, 2008 | 12:46 AM
Izero's Avatar
Izero
might want to get a grounding kit and a voltage stabilizer as well....
