int led light prob
Old Mar 8, 2008 | 05:21 AM
street and track's Avatar
street and track
Default int led light prob
hi dose any one no the anser to my prob i have just put in a red led int light/lamp looks great when it should but when its meant to be off its all ways on a really light bit is this normal for leds ben so low in current????
please help[:-]
Old Mar 8, 2008 | 01:59 PM
bone33's Avatar
bone33
Default RE: int led light prob
ORIGINAL: street and track
please help[:-]
i think you got your pc and your phone mixed up.
Old Mar 8, 2008 | 03:30 PM
street and track
ha ha ha
Old Mar 9, 2008 | 01:03 AM
djmagic's Avatar
djmagic
your dome light? if so mine stays on too
Old Mar 9, 2008 | 12:26 PM
street and track
ya i guess you could call it a dume light its just a really little bit it dont seem to be bothering the battery is this normal then
Old Mar 9, 2008 | 12:52 PM
Caraudioholic24's Avatar
Caraudioholic24
just need to know if the light is on bright or dim when the doors are closed. If it is dim there isa solution to fix it.
Old Mar 9, 2008 | 04:20 PM
DouglasSXT's Avatar
DouglasSXT
Yeah, mine will stay lit up on dimas well after opening the door... Was told by the company that sold me the light that it was normal and it would not run down the battery. So far so good, had it for about 7 months or so??? I guess it has something to do with current going to it, cause when left over night without a door being opened to trigger the light, it goes out???
Old Mar 9, 2008 | 07:06 PM
Caraudioholic24
Yea what I believe I think it is, When you close the door at night your light wont dim completely out. There is just enought voltage there to keep your led on. You cant see it witha regular bulb because the voltage is not enough to light the regular glasa bulb up, but a led is a lot more sensitive. After your car has been sittng for a while the cars keyless entry computergoes into like a sleep mode and shuts all the monitoring stuff down to conserve the battery. This happens in a lot of the new fords as well. I am MECP certified and when doing alarms and remote starts I come across this sometimes. The lights sometimes false out the alarms and make them go off. You could try putting in a small relay and send your own power to the led but I dont have a schematic made up for you. Let me know if you want to go through the trouble and I can try to make one up for you
Old Mar 10, 2008 | 06:45 AM
street and track
it gose on nice and brite when the doors open just goes on dim when it shouldnt be on i guess it just gettint a little current from some were i think i will leave it if its not bothering the batteryunless there is a quick proplem solver
Old Mar 10, 2008 | 11:28 AM
Yako's Avatar
Yako
its totally normal it wont dry out ur battery or anything, just think of it as in stand by mode
