Turbo
Old Mar 15, 2008 | 02:21 AM
fox02neon's Avatar
fox02neon
Default Turbo
Okay well I started my car after two long months. I need a little help with the vac lines. I have looked around and have not been able to acutually find a forum. I kinda have an idea, but would like to hear from someone that has done this. I am working with the srt set up. Can anyone help??? Thanks.
Neon 2002 2.0 SOHC
Old Mar 15, 2008 | 02:43 AM
GrApHite03's Avatar
GrApHite03
Default RE: Turbo
ORIGINAL: fox02neon
Neon 2002 2.0 SOHC
what exactly are you looking for?
Old Mar 15, 2008 | 01:20 PM
fox02neon's Avatar
fox02neon
Default RE: Turbo
I don't know where to hook up the vacuum lines.
Old Mar 15, 2008 | 01:28 PM
inthewerks's Avatar
inthewerks
Default RE: Turbo
do you have a starting location for these lines? it will be easier to help find where they hook up to if you have a starting point.
Old Mar 15, 2008 | 02:11 PM
fox02neon's Avatar
fox02neon
Default RE: Turbo
The problem I am finding is which one is which. I think the bottom lline (blow off valve) hooks up to the brake vacuum line. And the other bottom vacuum line hooks into the CAI? But I don't really know? I was thinking I could have some one look at there lines and help or something? Don't really know what else
Thanks
Old Mar 15, 2008 | 02:44 PM
SiX1N9N3's Avatar
SiX1N9N3
Default RE: Turbo
IF U DONT HAVE INSTRUCTIONS, KNOW WHAT THE HELL YOUR DOING, AND DONT HAVE SOMEONE WHO'S HAD EXPERIENCE AT YOURDISPOSAL WHY WOULDNT U JUST TAKE IT TO THE DEALER OR SOME PERFORMANCE SHOP TO PUT IT IN.... UNLESS YOU WASTED ALL YOUR MONEY ON A TURBO KIT WITH OUT MONEY TO SPARE? TAKE SOME PICTURES TO HELP US HELP U LOL
http://s259.photobucket.com/albums/hh285/six1n9n3/
Old Mar 15, 2008 | 02:59 PM
GrApHite03's Avatar
GrApHite03
Default RE: Turbo
ORIGINAL: fox02neon
Thanks
Any line having to do with the turbo is not a vaccum line. Your termonology is off. Lines to the WGA or BOV need a "boost" referense in order to work properly. CIA or brake vacuum line will never see any positive pressure resulting in your WG and BOV not working.
Size:  27.8 KB Name:  DSC01518.jpg
It's hard to tell from my photo... I suggest the wastegate have its own boost line. I also suggest this come from the intake manifold if possible. BOV referense should be after the TB.
As much as i did not like the guy above me yelling in all caps, he does have a point. If you don't have the slightest idea of anyting i posted you do need to uninstall your turbo kit.
k3v
Old Mar 15, 2008 | 03:26 PM
fox02neon's Avatar
fox02neon
Default RE: Turbo
I do have some help, is a cert. mechanic, but he has not install custom turbo's for a neons. this the last part so I needed some help with this part. Tha's why I also asked for some pictures. If I could look at a neon than It would not be an issue.
Old Mar 15, 2008 | 11:22 PM
djmagic's Avatar
djmagic
Default RE: Turbo
graphite has boost... guess you learn something new everyday
Old Mar 15, 2008 | 11:44 PM
fox02neon's Avatar
fox02neon
Default RE: Turbo
I found a diagram on the srt fourm that should work.
