Neon: Turn Signals Rapid Blinking
Old Dec 30, 2004 | 12:25 AM
Shelberado22's Avatar
Shelberado22
Default Neon: Turn Signals Rapid Blinking
I've went to a few places to find out what the problem could be and they all want to run expensive diagnostics on it.
What happens is that my turn signals blink quickly. Now that it's colder outside, the blinking fluctuates in frequency from what seems to be faster when it's colder. None of my lights are out and all of the fuses (in the interior box) are fine. When I use the turn signal, all the lights blink, just faster.
Any ideas? I'd appreciate it greatly!
**I thought I'd add that it's a 2000 Dodge Neon, if that's significant?!
Old Dec 30, 2004 | 12:26 AM
LoNeWuLf's Avatar
LoNeWuLf
Default RE: Neon: Turn Signals Rapid Blinking
You covered everything I could think of lol
Old Dec 30, 2004 | 02:50 AM
lonasindi's Avatar
lonasindi
usually if a light is blinking faster than normal, it means a bulb is out. but you said you checked them all and they're all good, so I really have no idea. Maybe try replacing lamps just to see if that makes it go away, maybe one is beginning to fail?
Old Dec 30, 2004 | 02:25 PM
Shelberado22
I'm skeptical about that solution, only because, like I said, the rapidity of the blinking changes with what seems to be either the amount of time/temperature of the car (or its environment) when running. Like, the warmer the car gets, the slower the lights blink.
Any other suggestions, people?!
Old Dec 30, 2004 | 02:37 PM
RcBandit28's Avatar
RcBandit28
Check your flasher.....I think it's located in the fuse box. It's a silver circular looking fuse thing. I had this happen on my 97 Ram, all the bulbs were good, but it had a bad flasher. Cheap fix. To test it, you should have seperate flashers for both the turn signals and the hazard lights, interchange them to see if that fixes your problem. Then replace the bad one.
Old Dec 30, 2004 | 06:41 PM
casper's Avatar
casper
I would alson say its the flasher. I believe the neon only has one for the turns and the hazards though.
Old Dec 30, 2004 | 11:05 PM
Cr@zy Squ33's Avatar
Cr@zy Squ33
Odds are it is the relay (flasher) for the bulbs.
Old Dec 30, 2004 | 11:40 PM
Shelberado22
OK, stick with me here...
Are you talking about the fuse box under the hood, or in the interior of the car?
I checked the interior fuse box (it's raining, so I haven't checked the one under the hood yet) and there were no large fuses except 1, which cut off my headlights when I removed it. Otherwise, my little fuse for the turn signals is not blown.
Any paticular fuses/fuse boxes/things I should be looking for to determine the cause? I haven't let up on the fuse theory, but I just can't find which it would be!
Appreciate it
Old Dec 30, 2004 | 11:47 PM
Cr@zy Squ33
In the car on the driver's side you'll see a little box where the fuses are. Along side of the fuses you'll see I believe a green and a black relay. One of them should be for the turn signals.
Old Dec 30, 2004 | 11:54 PM
Shelberado22
Ok.. I see the green relay beneath the fuses, and there is a spot for turn signals 'n hazard lights. There aren't ANY fuses plugged in there.. would that be the problem?
