2000 Neon - no reverse!
Old Mar 29, 2008 | 01:43 PM
BlueMonster's Avatar
BlueMonster
Default 2000 Neon - no reverse!
My 2000 Neon has no reverse, it's been getting weaker for a long time and it finally stopped engaging completely. First gear is perfect. I recall once being told about a tab or bracket or something simple inside on the reverse band maybe that bends. Supposedly an easy fix once you get inside the trans.
Sound familiar? I need this car working again ASAP!
Old Mar 29, 2008 | 04:22 PM
BlueMonster
Default RE: 2000 Neon - no reverse!
FYI, it's a 4 cyl/auto
Old Mar 29, 2008 | 04:39 PM
bone33's Avatar
bone33
dont back up. how hard is that.
Old Mar 29, 2008 | 04:48 PM
BlueMonster
Easy enough. Thanks for the help.
Old Mar 29, 2008 | 04:58 PM
bone33's Avatar
bone33
ORIGINAL: BlueMonster
see, problem solved.
Old Mar 29, 2008 | 05:45 PM
BlueMonster
I wish.
In searching, I found several other posts with a similar problem, but no answers...
Old Mar 29, 2008 | 06:07 PM
bone33's Avatar
bone33
are you sure that its going all the way into gear? try moving the lever towards park to see if it will engage up there and if it does then its out of adjustment.
Old Mar 29, 2008 | 06:09 PM
BlueMonster
Yup, tried that. No luck. It's been slipping in reverse for a long time, we dealt with it, but now having zero reverse is unacceptable!
Old Mar 29, 2008 | 06:14 PM
BlueMonster
I can hear the RPMs drop slightly in reverse, so something is trying, but no actual moving backwards.
There is supposedly a plate attached to the band that bends? and causes it to do this? That is what I am searching for.
Is there a manual online somewhere with good internal trans diagrams?
Old Mar 29, 2008 | 06:15 PM
bone33's Avatar
bone33
since you have a 2000, thats a 3 speed. i think its the same one or similarthats in the first gen neons. this post https://dodgeforum.com/m_88686/tm.htmhasgreat adjustment procedures in it.
