Motor Mounts
Old Apr 9, 2008 | 12:40 AM
2003SXTneon's Avatar
2003SXTneon
Default Motor Mounts
I just got my MM any tips or suggestions?
Old Apr 9, 2008 | 02:36 AM
Freerider's Avatar
Freerider
Default RE: Motor Mounts
The Prothane Inserts or New Motor Mounts?
If you got the prothane Motor mounts I have a whole thing on my Cardomain on tips and personal experience.
Old Apr 9, 2008 | 11:26 AM
blackflame's Avatar
blackflame
ORIGINAL: Freerider
Take his tips! When I did mine it took me forever because people were telling me to cut and stuff. I didn't know what to cut because I couldn't see. Then I wasn't sure how far the thing had to go in and...wow, it sucked.
Old Apr 9, 2008 | 11:29 AM
whtdoesitmatter's Avatar
whtdoesitmatter
use lock tite on ur bolts!!!
Old Apr 12, 2008 | 03:30 AM
2003SXTneon
i got the prothane inserts. did you guys torque the bolt?
Old Apr 12, 2008 | 03:40 AM
Freerider's Avatar
Freerider
You just need to tighten them, and give them 2-3"oh *****" or grunts.
But, be sure to use LOCTITE!! If you don't it might vibrate/ work itself out...
My inserts came with loctite. I don't know if yours did or not.
Old Apr 12, 2008 | 08:17 AM
spikeymikey87's Avatar
spikeymikey87
dont forget to support the engine
use jackstands
have an 18mm socket or wrench lol
Old Apr 12, 2008 | 06:28 PM
2003SXTneon
cool sounds good. thnx for the input/suggestions.
heyfreerider where did u buy ur MM from?
Old Apr 12, 2008 | 08:55 PM
Freerider's Avatar
Freerider
Howell, unfortunately. They were the only thing I ever ordered that shipped the next day
Old May 13, 2008 | 11:46 AM
nicolasl46's Avatar
nicolasl46
i ordered those prothane motor mount, and a set of upper and lower engine mounts, when i put the inserts, i had to cut little pieces of it, and also the left over rubber in the engine mount. But after installing everything, my car started shaking like a mixer. I wopuld stop on a red light and the engine will sit idle on gear, and started shaking like crazy. I had to put everything apart again, took aout the motor mounts, and now the engine feels smooth, it only shakes when i start the engine, and thats it. I don't recommend the prothane mounts, it makes the engine to rigid, it looks like is going to breake or something, plus my steering column would shake as much as the car when idle.
