three inch drop wanted
Old Apr 15, 2008 | 11:30 PM
inthewerks's Avatar
inthewerks
Default three inch drop wanted
hey everyone. just wanted to know about dropping my car another inch or two. currently at two inches lower. since im back on my stock sxt rims again, i want to tuck the tires a little bit. i know the sxt only has a total of around three inches of travel but if i cut the foam bump stops on the struts and cut one coil from each spring, will that work?? my springs are currently rated at 230 lbs front/ 200 lbs rear. let me know if this is possible. if not, how else can i achieve this 3-4 inch total drop. thanks.
Old Apr 16, 2008 | 12:06 AM
01neon01's Avatar
01neon01
Default RE: three inch drop wanted
bag it. thats the only way i can think for you to be able to tuck your neon. plus that way you can adjust it so you can actually drive the car.
Old Apr 16, 2008 | 02:43 AM
Kalevra's Avatar
Kalevra
ORIGINAL: inthewerks
DO NOT CUT THE COILS!!! you'd only be asking for trouble if you do. Just bag it. it's the only way you can achive a 3 inch drop.
Old Apr 16, 2008 | 05:05 AM
j_son600's Avatar
j_son600
1st gen Skunk2 springs will drop you about the 3" you are looking for, had mine on for over a year and love them. I think neon chick has them and ended up putting a 1" spacer cuz they where a little to low for her. On level ground mine sits 3 - 3 1/2" ground to frame.
Old Apr 16, 2008 | 05:19 AM
N30N's Avatar
N30N
ORIGINAL:1st gen Skunk2 springs will drop you about the 3" you are looking for, had mine on for over a year and love them. I think neon chick has them and ended up putting a 1" spacer cuz they where a little to low for her. On level ground mine sits 3 - 3 1/2" ground to frame.
wow dude that looks nice.
Old Apr 17, 2008 | 12:10 AM
inthewerks's Avatar
inthewerks
i just looked at those skunk2 springs along with some other brands and i noticed that the springs are different enough to maybe posing a problem setting in my struts. are there any mods needed to get those first gen springs in a second gen strut??
Old Apr 17, 2008 | 02:16 AM
j_son600's Avatar
j_son600
No mods needed mine went on my stock struts just fine, reminds me I need to get new struts.
Old Apr 17, 2008 | 02:30 AM
contagious19's Avatar
contagious19
buy my springs wen i get my air ride
